Old 13th January 2013, 07:59 AM   #11
Igor is offline Igor  Serbia
Your cnc work already look amazing! My friend and me use 19th century technology hehehe
Old 14th January 2013, 12:09 AM   #12
Igor, thanks. I wouldn't have tried this radius style cabinet design without having access to a CNC. Here is how I ended up the day, still a long way to go;
Old 15th January 2013, 07:28 PM   #13
Default Driver dimensions
For those that might be interested here is a sketch of the driver locations. image.jpg
Old 27th January 2013, 06:07 PM   #14
Default Woodwork about complete, on to paint prep
Old 29th January 2013, 02:15 AM   #15
Default Driver test fit
I couldn't help myself! Had to get the drivers out of the boxes and see how they fit.
A lot of prep on the front baffle. Besides laying up 3 layers of plywood to get to 1 7/8" thick, then routing out for the sides and intermediate braces to mortise into, all the driver holes had to be back-cut to allow the rear of the drivers to breath.
Old 30th January 2013, 05:14 AM   #16
Default Picked up primer and paint
I'm going for a deep piano black finish. The speakers will be placed in our living room close to the windows. Here in Honolulu we get mostly sunny days so UV protection is very important. So I'm using Duponts best line of automotive finish.
The plan is 2-3 coats of the primer, 3 coats black basecoat, 3 coats clear, wait 24 sand with 500-600, then 3 more coats of clear, wet sand, then polish and wax.
Old 30th January 2013, 07:39 AM   #17
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Looking great, classic black coffin speaker!
How is the humidity in Honolulu? Perhaps some primer also inside the br-box to prevent deformation and decoupling ?
My DIY speaker history: -74 Philips 3-way, -82 Hifi 85B, -07 Zaph L18, XLS10+PR/Hypex, -08 CSS125FR, -08 Hifitalo AW-7, -08 TangBand FR, -09 MarkK ER18DXT, -13 PPSL470, -13 AINO GRADIENT
Old 30th January 2013, 02:29 PM   #18
Being a body shop owner let me warn you!
Seal the wood with wood rot epoxy sealer then use nason
Ful-pox primer! Careful not to run the primer it's very thin!
This should be a five day process
Old 30th January 2013, 03:04 PM   #19
Juhazi, thanks for the reply. The interior of the cabinet is entirely covered with 2 layers of 3M 08840 sound dampening material. (Bitumen). The pads are self adhesive but I sprayed the complete interior with contact cement to both seal the wood and make sure pads never come loose. The backside of the front baffle will be sprayed with primer before being permanently attached. Here is a pic of what the material looks like;
Humidity in Honolulu is not near as bad as in some other cities in the US, but a concern with anything that could be affected by it.
Old 30th January 2013, 03:17 PM   #20
JonasKarud's Avatar
Nice work!
Looking forward to see the end result!
Ekta Grande baffle changes dublin78 Multi-Way 6 11th October 2011 03:40 PM
B&W683 or EKTA Grande? junjuvava Multi-Way 4 13th March 2011 09:35 PM
Is nxV200 and Ekta Grande junjuvava Solid State 0 2nd March 2011 05:33 PM
New Ekta Grande/ZRT varation dotvibe Multi-Way 18 24th July 2010 05:36 AM
Ekta Grande cabinet size? dublin78 Multi-Way 1 22nd July 2010 04:41 AM
Copyright ©1999-2013 diyAudio
