have 4x exodus woofers and 2x morel et448 - what to do?
Old 7th January 2013, 06:58 PM   #1
audiothings is offline audiothings  India
Default have 4x exodus woofers and 2x morel et448 - what to do?
we bought 4x exodus woofers and 2x morel et448 tweeters for a project. it got held up and by the time it started again, i had decided to go with a different design - 4Pi speakers by wayne parham... as it happens.
now, a guy who i owe money to, is not allowing me to return the money, instead, he insists that i should build him a pair of speakers... what is the best use i can put these drivers to - form factor is not a constraint, at this time - though i'm guessing that a vented floor standing M-M-T design will serve him best... it will serve as his music playback device in his 14' x 24' living room.
since i know nothing about electronics (or much else) i am hoping that I can use a prefabricated crossover such as this one from PE, with, possibly a variable attenuator for the tweeter, in order to match the sensitivity of the woofer...
suggestions, warnings etc welcome.
Old 7th January 2013, 07:17 PM   #2
R.I.P.
He'd be better off with the money if your considering
such an awful crossover for $600 worth of drivers.
Its not that simple, by a long way.
rgds, sreten.
Old 7th January 2013, 07:30 PM   #3
Kjeldsen is offline Kjeldsen  Denmark
sreten are correct on this one. But, if you wan't to try something simple try this
AR-SXO - Acoustic Reality - Designed and built in Denmark
I have tried it, and it's not perfect for all woofer/tweeter combinations, but it's worth trying. Why? It's a very simple series cross over, and you can get good results by ear.
It might not be perfect, but with at bit of luck it might sound good.
Old 7th January 2013, 07:41 PM   #4
R.I.P.
Its still not that simple, by a long way. Not for a MMT.
rgds, sreten.
Old 8th January 2013, 07:07 AM   #5
Sreten, I appreciate your frankness. Quite certain I have asked a terribly n00b question, and the answers are too complex to even begin to explain.
Should I consider MINI DSP, and two power amps?
Can I get somebody to design a pair of crossovers for these?
What are my options? As noted, the drivers are quite good at what they do, and worth some money... but they are useless to me, and I'd find it very hard to sell them, where I'm at.
What if I opted to go for a single midwoofer? Would the acoustic reality crossover work?
He'd be better off with the money if your considering such an awful crossover for $600 worth of drivers.
Just to be clear... a friend of mine did me a professional favour, and much as I'd like to pay him for it, he won't accept money. He agreed to take the speakers, he did not insist on it as I had previously indicated I have carpenters working on another unrelated project, and these fine drivers to expend, so everyone can win...
Old 8th January 2013, 07:43 AM   #6
momomo67890 is offline momomo67890  United States
UMIK-1 | miniDSP
grab one of these also and u will easily be able to figure out the xo if your using a mini dsp
have 4x exodus woofers and 2x morel et448 - what to do?Hide this!Advertise here!
4x Simplistic Mosfet HV Shunt PCBs +2x assembled heaters DIYspaceW Swap Meet 23 9th August 2011 01:05 PM
FS: 4 Exodus DPL-15 Woofers audiophiliac Swap Meet 0 30th September 2010 02:36 AM
For Aussies/NZ: PHL, Morel, Exodus Audio, Hiquphon... tktran303 Multi-Way 5 25th May 2008 02:35 PM
FS: 4x Hammond 373BX transformers, 2x Goldpoint attenuators (MH-SA-25k) moomoo Swap Meet 6 17th May 2005 04:57 AM
FS: 4x Hammond 373BX transformers, 2x Goldpoint attenuators (MH-SA-25k), and more moomoo Swap Meet 2 10th November 2004 06:51 AM
