WinISD Graph Range - diyAudio
Old 7th January 2013, 12:38 AM   #1
atnaat is offline atnaat  Wales
Default WinISD Graph Range
I'm using WinISD non pro so I can export the graph data toa txt file but I can't change the graph range on WinISD. When I right click on the graph the range goes from 10Hz to 1Khz and is grayed out. Anyone know how I can get around this?
Old 7th January 2013, 11:54 PM   #2
haven't used Winisd for ages, but isn't this hidden in the menus somewhere?
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 8th January 2013, 02:14 AM   #3
Graph settings should be under File, Options.
Insert witty signature line here.
Plotting the graph nicholas1113 Solid State 1 21st May 2011 04:04 PM
what is an FFT graph? keantoken Everything Else 23 10th September 2006 01:13 AM
How to determine Q from a graph? JoeBob Parts 4 13th November 2004 05:12 AM
What graph to look at? pjacobi Solid State 3 18th February 2004 02:56 AM
Need explanations on WinISD Gain/phase/group delay graph Tired Multi-Way 1 23rd June 2002 06:26 AM
Copyright 1999-2017 diyAudio
