How does this crossover work? (pics) - diyAudio
Old 4th January 2013, 10:38 PM   #1
Default How does this crossover work? (pics)
This is a crossover from a set of JBL GTO607C car component speakers. I was originally considering using it for a boombox project, but I think I've figured out it wont work, now I'm trying to figure out why.
The specs for the set say that it is a 12db/octave 4000hz crossover (for 2 ohm speakers)
But it only has 1 cap and inductor each, and is set up oddly.
I don't know what i'm doing! Here is pictures of the front and back, and a sketch i made for myself to try to figure out how its laid out. Any help would be greatly appreciated.
Old 4th January 2013, 10:50 PM   #2
tuxedocivic's Avatar
It's a single order electrical high pass on the tweeter and low pass on the woofer with an optional series resistor on the tweeter. The tweeter is wired out of phase with the woofer.
Looks like a crappy cross over.
Old 4th January 2013, 11:02 PM   #3
Cool! That's what i thought, but i couldn't figure out how they got 12db/octave with that setup, and why the tweeter would be out of phase.
Would it be safe to rob the capacitor out of them if I decide i could use them?
Looks like I could use the 4.7 uF Cap for a simple high pass for an 8 ohm tweeter (about 4220 hz) if i wanted to. If the inductor was marked i could consider using that also, but i don't know how to tell what it is.
Old 4th January 2013, 11:22 PM   #4
wintermute's Avatar
Probably the marketing dept got involved
Depending on the drivers used, it *may* result in a 2nd order rolloff when combined with the drivers natural rolloff (my original MTM crossover I used 1st order electrical on my tweeter to get 2nd order accoustic rolloff), however it is much more likely to result in a 3rd order acoustic rolloff (at least on the bass side).
With a 3rd order rolloff, in theory it should not matter which way around the tweeter is mounted, in practice however one orientation will likely give better results than the other.
In all instances I would be VERY surprised if it results in an optimal crossover regardless what drivers it is connected to
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 4th January 2013, 11:51 PM   #5
Thanks! I think ill go ahead and attempt to build my own... Is parts express the best place for cheapish caps/inductors?
Old 6th January 2013, 12:14 AM   #6
If you are looking to save money, Parts Express I think is generally much more expensive than other vendors. I think that most likely you would find much better prices on the least expensive capacitors (bipolar or non-polar electrolytic) and inductors at MCM Electronics, Mouser Electronics, and/ or Digi-key. As far as I know, though, Mouser and Digi-key don't sell inductors suitable for use in cross-over networks.
Pete
Old 6th January 2013, 03:43 AM   #7
Thanks! I was looking for another source... How do I tell if they are decent audio quality components?
Old 6th January 2013, 05:40 AM   #8
balerit is offline balerit  South Africa
balerit's Avatar
That's a 6 dB sloped filter and the tweeter is incorrectly wired.
Old 6th January 2013, 05:56 AM   #9
Pano is offline Pano  United States
Pano's Avatar
Parts-Express or Madisound for crossover parts. I don't think you'll find what you need at Mouser or Digikey. Great for other stuff, tho.
Old 6th January 2013, 07:26 AM   #10
wintermute's Avatar
Parts connexion is also not a bad place for at least crossover caps (if you want low cost good quality) I use their very inexpensive axon caps AXON True Cap Metallized Polypropylene Capacitors Note that they also have "boutique" stuff some of which will cost more than expensive drivers!!!
They have inductors as well, but I'm not sure how they compare price wise as I made my own
Tony.
Some of my photos
W-MT-W Work-in-progress pics and rambling cause I'm bored tresch Multi-Way 0 23rd June 2009 10:16 AM
custom crossover pics DerrickM Car Audio 0 27th March 2007 05:19 AM
How to wire inductor in crossover??PICS* Dominick22 Multi-Way 26 29th August 2006 09:31 PM
Testing drivers & crossover pics mattpman Multi-Way 3 5th January 2004 01:24 AM
Some pics of my P2P alephP (work in progress) stappvargen Pass Labs 29 28th December 2003 07:14 PM
Copyright 1999-2017 diyAudio
