Old 14th November 2003, 01:01 AM   #1
r0cket- is offline r0cket-  United States
Default What to do with this sub
Picked up a cheap old Realistic 12" passive sub a couple months ago, and while I've been fairly underwhelmed by its performance, I hate to just chuck the thing. So I'm thinking maybe I can ditch the stock driver and crossover and just reuse the cabinet...
Internal dimensions are 10"(W)x17"(L)x9.5"(H). The box is ported and down-firing, but I could probably seal it up and flip it on its side if need be. Any suggestions for a driver? I checked partsexpress.com's speaker selection wizard, and it gave me two possibilities (Pioneer A30IR50-51F and Pyramid PW1258-US) for use with a sealed box of that volume, and none for use with a ported box.
Anyone have any suggestions or advice on this?
Old 15th November 2003, 10:47 PM   #2
mikee12345's Avatar
so its less than 1 cube we use metric here..
seal it up,as its probably not tuned right for any other woofer.
and get a little 10" or something
i think a pyramid would be unremarkable
link
=average car sub.
or design a ported box for a peerless 10"(more quality)
link
Old 15th November 2003, 11:11 PM   #3
JCoffey is offline JCoffey  United States
Well, I had that same sub for along time. Come to find out, Pioneer made the driver for it. So it would probably not do you any good to use the pioneer since it wont boost performance. I would Possibly recommend www.apexjr.com and getting the Cerwin Vega amp for $60 and give yourself a powered amp for a computer system......
Old 16th November 2003, 01:00 AM   #4
Default Re: What to do with this sub
Originally posted by r0cket-
Picked up a cheap old Realistic 12" passive sub a couple months ago.....So I'm thinking maybe I can ditch the stock driver and crossover and just reuse the cabinet...
A) Plan on running this from a sub amp/crossover from Parts Express or Madisound or from the regular amp/receiver? There are dual voice coil choices that will allow you to use regular amp setup.
B) Most subwoofer amp/crossovers are 4 ohm output, which is fine. If you plan to use this in dual voce coil mode, what is the ohms of your regular amp- 8 ohms, 6 ohms, or 4 ohms?
Note: Pioneer makes a lot of 6 ohm drivers. You might want to take a meter and measure the DC resistance of the driver you are abandoning.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Page generated in 0.06734 seconds (75.24% PHP - 24.76% MySQL) with 9 queries
