Canned Crossover Design - What Next? - Page 5 - diyAudio
Old 15th January 2013, 08:36 AM   #41
ODougbo is offline ODougbo  United States
Mike,
Will Box Port II switch over to rectangle ports? - WinISD didn't like all the manipulation, but this what I came up with.
I'd like to keep the box about a 1" less deep than the TB, i.e 9".
(the extra white line is exaggerated)
Old 16th January 2013, 09:36 AM   #42
A few revelations:
Both woofers TB W5 - SF W7 are about the same size (OD), so the TB box is a good example (e.g. don't want to get close to edge at front)
Using same footprint as the TB box, cut about the 1" off the back, that will make the ID height 11" (for a 13 liter box).
(the TB W5 box is 14-1/2" ID)
Going to use scrap wood and build one test box, make sure there is minimal port noise.
[W5- W7 - W BOX - How'd that happen?]
Old 16th January 2013, 04:58 PM   #43
Michael Chua's Avatar
Originally Posted by ODougbo View Post
Mike,
Box Port II doesn't have rectangular ports.
I think my Bass Box 6 can do that. I will check it out for you later. Haven't use Bass Box for a while.
ampslab
Old 16th January 2013, 07:11 PM   #44
just another
wintermute's Avatar
If you really want to get your teeth into something, you could try akabak
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 16th January 2013, 08:35 PM   #45
Akabak? Oh Boy.
Speakers are in, nice to look at, pretty good sized magnets.
Working on test box now.
Old 17th January 2013, 02:52 AM   #46
Originally Posted by wintermute View Post
If you really want to get your teeth into something, you could try akabak Tony.
Hi Tony
Thanks for the recommendation. I heard that akabak is very powerful. Trouble is I don't have the time for steep learning curve. Too much work already.
Hi ODougbo
I simulated the W17RC with Bass Box. The 2" diameter port length is almost the same, which means both are accurate.
For a rectangle port:
Height = 0.5"
Width = 6"
Length = 6.9"
A 1 inch height is not practical. Length is more than 12".
ampslab
Old 17th January 2013, 03:07 AM   #47
What am I tuning to? Might be good to put it in writing.
(stopped by HD picked up 12/ MDF for vent pieces)
Old 17th January 2013, 03:10 AM   #48
Box Tuning (Fb) = 49Hz
ampslab
Old 19th January 2013, 07:44 PM   #49
So going as planed. Used square vent strips just in case this is a flop (port noise).
Tuned at 43hz now and sounds fine; will cut flares in ports (vent strips) - to move tuning up to 49hz.
Old 19th January 2013, 10:57 PM   #50
Looking great. Are you able to check on the vent tuning?
ampslab
Need help with 2 way crossover design Needadispenserhere Multi-Way 11 11th February 2011 01:13 PM
FS: low noise, sealed canned transformer 60-0-60vac gengis Swap Meet 4 5th January 2008 12:44 AM
FS: Potted and Canned 700VA Toroids K-amps Swap Meet 1 23rd November 2005 12:39 PM
Help with a crossover design... BAM Multi-Way 0 15th October 2003 02:01 PM
Crossover design. bets. Multi-Way 6 27th July 2003 06:45 PM
Copyright 1999-2017 diyAudio
