Canned Crossover Design - What Next?
Old 16th April 2013, 07:57 PM   #141
ODougbo is offline ODougbo  United States
Are these two resistors an L PAD?
Am I getting warmer
Old 17th April 2013, 12:13 AM   #142
gman76 is offline gman76  United States
Originally Posted by ODougbo View Post
Tried the xo in last post - okay, thought I lost some bass with the 16g series woofer coil. I switched it out with a 14g and used 14g feed wires, quite the improvement (bass).
I thought the tweeter sounded a little hot on some songs, so swapped the 1st tweeter resistor; 2.2ohm with a 3.3ohm ....They sounds nice, they pound, kick, slam and have nice high end.
(ordered some steel lam inductors - will try that next)
Visions of the DQ10 are coming back ...
Last edited by gman76; 17th April 2013 at 12:28 AM. Reason: EDIT: referring to photo of xo on top of cabinet with tweeter seemingly stand-mounted
Old 17th April 2013, 08:23 AM   #143
I saw that "cut-out" on here somewhere, it seems to enhance the imagining.
Going to experiment with the tweeter LPad, make sure I'm not missing out something good. Not sure why it is in there:
SF 8" is 93.7db
ScanSpeak Tweeter 91.4db
[soon will try the ScanSpeak with smaller 6.5"]
Old 19th April 2013, 12:18 AM   #144
Penny pinching here, resorting to cardboard. Will fit into base/stand soon.
Old 21st April 2013, 10:32 PM   #145
Still going here, made a 3rd 8" box. It is a little smaller and tuned a just a bit lower. Also added damping wool to both, 8.5 oz.
[also used better grade wood]
Results, more bass and better middle, the tweeters are starting to shine a bit. I had to move the speakers out from the wall, was starting to pick up some boom.
Still really happy with the 6.5" and vifa, that's a good little speaker; too bad the cost of copper is so high now (that runs up the price on a set).
Old 25th April 2013, 09:55 AM   #146
Pic of # 3 8" SF woofer/Discover tweeter.
Still not as much deep bass as the 6.5" (although its not a wimp either).
Going to start #4 today, not sure what to try next, maybe reducing box size another 50 square inches.
[but it all works together, e.g. box depth/height control vent sizes]
Old 26th April 2013, 08:48 AM   #147
Pic of #4, this one has more of a "biff" than a "boom" so maybe this is the ticket. [there are a few small improvements]
*** Would like to try a 6.5" MTM (2nd pic), in a 24 - 25 liter "tower", again xo is a roadblock.
I'm guessing 2 - 4ohm or 2 - 8ohm woofer combinations is typical; next question would be would there be two inductors - or just one
Old 26th April 2013, 02:43 PM   #148
chazdrumzalot is offline chazdrumzalot  United States
Using 2 8ohm drivers in parallel will result in a much more efficient, 4ohm speaker; If you arranged them in a 2.5way configuration then you could just use a single inductor on the bottom woofer to roll it off at baffle step. But I think the crossover would have to be redesigned, at least to the extent that different values would be needed to compensate for the lower impedance of the two woofers.
Then again, what do I know?
Old 26th April 2013, 03:05 PM   #149
2.5 vs. MTM
www.madisound.com/kits/2.5-way-kits.php
Old 27th April 2013, 12:21 PM   #150
Much fun
Can anyone tell me what's the difference between MTM and a 2.5?
Canned Crossover Design - What Next?Hide this!Advertise here!
Need help with 2 way crossover design Needadispenserhere Multi-Way 11 11th February 2011 01:13 PM
FS: low noise, sealed canned transformer 60-0-60vac gengis Swap Meet 4 5th January 2008 12:44 AM
FS: Potted and Canned 700VA Toroids K-amps Swap Meet 1 23rd November 2005 12:39 PM
Help with a crossover design... BAM Multi-Way 0 15th October 2003 02:01 PM
Crossover design. bets. Multi-Way 6 27th July 2003 06:45 PM
Copyright ©1999-2017 diyAudio
