Old 30th January 2013, 08:03 PM   #11
thx Bjorno, I just finished the speaker.
I did as you suggest, the 160 liters one.
It's sounds a little strange in the frequency response, there's a huge gap in the between the 40-55Hz and 70-90Hz with almost -13dB lower with the 85Hz frequency, while the 60Hz is +6,8dB louder??? what went wrong?
I meausured some frequencies between 20 and 100Hz and came wth the following numbers:
Hz dB Variation
20 85,6 0
25 86,1 0,5
30 93,6 7,5
35 97,6 4
40 104,4 6,8
45 103,2 -1,2
50 97,9 -5,3
55 97,7 -0,2
60 104,3 6,6
65 109,9 5,6
70 100,9 -9
75 98,5 -2,4
80 95,1 -3,4
85 82,3 -12,8
90 87,1 4,8
95 91,9 4,8
100 95,5 3,6
I would like to hear some suggestion of where did I went wrong. I'm using an active crossover crossed at 200Hz to my scan speak 8545 midbass.
Thx
Murillo
Old 30th January 2013, 08:13 PM   #12
just another
wintermute's Avatar
Were those measurements taken in room? It seems as though you may be seeing room effects. What do you get if you do a nearfield measurement of the cone and port (or even put the mic inside the speaker cabinet?
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 30th January 2013, 08:23 PM   #13
hi Tony, the mic was inside the port. Thx for asking.
Old 31st January 2013, 01:27 PM   #14
update, I used an FFT software and its flat.Í may have made a wrong measuring procedure.
Thx for all help.
bass reflex tuning compensated by wall ? gougigaga Full Range 16 13th June 2012 10:04 PM
How accurate does bass reflex tuning need to be? dublin78 Multi-Way 30 26th May 2012 09:20 PM
Fostex FP203 in bass reflex, tuning? slackweather Full Range 11 7th August 2011 08:58 AM
Tuning bass reflex port beamnet Multi-Way 0 28th September 2005 01:03 PM
Bass Reflex Enclosure & Port Tuning D_GR8_1 Multi-Way 2 2nd December 2004 09:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
