Old 3rd January 2013, 05:47 PM   #1
Default "Spare Parts" Bluetooth Boombox crossover and design help.
So, I've been itching to build a semi-portable boombox that I can pick up and relocate easily, something I can use in our bedroom, in the garage, workout room, or outside.
I'm trying to do it without buying any additional components. I've gone digging through my spare parts pile and have located some things that i think might work for a semi-hifi ghetto blaster type thing...
The speakers:
Morel MDT 12 Tweeters (missing front mounting plates) Morel MDT 12 1-1/8" Neodymium Tweeter 277-060
Aura NS6-255-8A 6" woofer
Aura NS6-255-8A 6" Paper Cone Neodymium Magnet Woofer 299-030
The crossover???
I have a set of crossovers leftover from a set of JBL component speakers... they have a 4.7 uF Capacitor on them, as well as a tweeter attenuation resistor and switch, and an unmarked inductor.
pic of the crossover:Click the image to open in full size.
According to my calculations, going by the capacitor, and for 8 ohm speakers, these should give me around a 4220hz first order crossover point, which isn't ideal, but should work ok.
Am I assuming correctly for this crossover? im an amateur when it comes to crossover stuff.
Other parts:
Ill be building the box from scratch, and incorporating a leftover 2020a+ amp Amazon.com: LP-2020A+ Lepai Tripath Class-T Hi-Fi Audio Mini Amplifier with Power Supply: Electronics
As well as a logitech bluetooth adapter for optional bluetooth connection.
Im a bit unsure on the box design also... Like i said, i'd like to keep it fairly compact, but keep some respectable bass output. I cant decide whether i'd be better off with a small sealed or small ported setup. Ive got a little bit of modeling to do for that i suppose.
Old 4th January 2013, 07:59 PM   #2
Dang... no help eh?
what if i sweeten the deal with a couple renders of what I hope this thing will look like when Im done?
bluetooth boombox noise problems... help! torclausen Class D 11 15th September 2012 04:09 PM
Bluetooth Boombox SHAD0WF0X Digital Source 4 25th March 2012 01:26 AM
"Dipol 08" Baffle Dimension and List of Crossover Parts LineArray Full Range 37 3rd March 2012 11:09 AM
FS: 100 small parts, R,C,Reg, Op Amps and more! All parts usable in "O2" DIY Project imminentdomain Swap Meet 2 30th January 2012 01:45 AM
Ultra Portable Bluetooth Boombox Project - need some help pigboi808 Chip Amps 0 28th August 2011 05:08 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
