Old 3rd January 2013, 02:04 AM   #1
WILD1 is offline WILD1  United States
Default Altec 604 C
Hi everyone
Haven't posted in a while but there is a local man wanting to sell an Altec 604C coaxial. I have a question about the impedance's that I want to check. What is the individual impedance for each of the drivers low and high. All the literature that I can find says 16 nominal. They do not say whether that is for each driver or a combination at the crossover . It would seem to me that each driver would have an impedance of 16 ohms which makes sense to me because in parallel they would draw 8 ohms. 16 ohms at each driver terminal and 8 ohms at the input to the crossover divider. Now I realize that those readings are nominal over a wide range of frequencies. Why I ask is because I want to check the drivers when I go look at it. On Ebay there is a guy listing two 604Cs and saying the impedance of the drivers are 8 ohms and he is showing a reading of the cone driver of one at 10.5 ohms and calling it an 8ohm driver. On the other speaker he is showing an impedance of 7.5 ohms at the cone driver and 7.6 at the horn driver which would be more normal for an 8 ohm driver. In another ad a lady is showing one and saying the impedance at the crossover or divider input is 16 ohms. This doesn't make sense unless they are driving the two drivers in series. If someone can clarify this for me I would appreciate it. I just want to be able to walk in check the drivers and know what he has.
Thank you,
Tom Wild
Old 3rd January 2013, 11:47 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
I measured what the owner said were 604C's - the woofers measured 8.1 ohms DC and the tweeters 7.5 ohms. YMMV as I am not an "altec expert".
The crossover does not change the impedance in the way you are thinking - there is no series or parallel effect on impedance from a crossover.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
Old 3rd January 2013, 11:53 PM   #3
Speakerholic
Cal Weldon's Avatar
Hi Wild1, They are nominal 16 ohms and often have a DC resistance of 8-10 ohms. That is if they are original comes and diaphragms.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd January 2013, 11:55 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
comes ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 3rd January 2013, 11:57 PM   #5
buzzforb's Avatar
Wow, that derailed quickly
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 4th January 2013, 12:02 AM   #6
Speakerholic
Cal Weldon's Avatar
Spelling Nazi strikes again.
Old 4th January 2013, 12:05 AM   #7
Zen Mod's Avatar
we luv ya , Big Cal ........ and you know that ......
Old 4th January 2013, 05:52 PM   #8
Default Got It!
Well I just got back from the bg H [Houston] . Saw some old friends from college and saw the speaker. The impedance of each driver was 12.4 which I would think a 16 ohm driver would be. This thing looks new other than two tears to the original cone which I think can be fixed. He tore it getting it out of the cab. Cost me $200. Now all I need to do is find another one for $200 LOL. The crossover was not hooked up to it but I'm thinking that impedance at the input of the crossover with the two drivers hooked up is going to be 8ohms. I just can't see how you can not have a cumulative effect from combining two impedance sources In parallel a decrease and in series an increase. Although I have been wrong before. Will post result.
Tickled pink,
Tom Wild
Old 4th January 2013, 07:43 PM   #9
Speakerholic
Cal Weldon's Avatar
Hi Tom, glad to hear you are now the proud owner of a 604. I know I felt the same way when I got mine.
On to the XO and impedances. If you were dividing the entire frequency spectrum between two drivers then yes you would divide the impedance in two - but you're not doing that. You have divided what each speaker gets via the crossover so each part of the spectrum only sees one driver so the rated impedance stays the same. The woofer is offering 16 ohms nominal to the amp as it and only it are delivering the bass notes. Same with the tweeters.
Old 4th January 2013, 11:36 PM   #10
Default I get it
Appreciate it Cal and I think I get it now. When I got them into the shop and measured the impedance it was also more like what you guys said it would be 7.9 to 8.1. It seems that you have a fancy for Tequila [Margaritaville]. Next time your in Texas give me a holler and we will spend a day eatin barbecue, drinking good mexican beer & siping some fine vintage tequila while listening to my 604s.
Thanks,
Tom Wild
Altec 604 D or E wanted..! alexismaster Swap Meet 0 14th August 2011 02:51 PM
WTB ALTEC 604 in any condition dwhitf Swap Meet 5 7th March 2011 03:01 AM
Altec 604 vs. 605 korneluk Multi-Way 4 23rd March 2009 12:50 PM
Horn enclosure for Altec 604 Coaxial ericimage Multi-Way 8 1st June 2004 03:01 PM
Altec Lansing 604-8L? GeorgeJ Multi-Way 4 21st March 2004 12:35 AM
Page generated in 0.11872 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
