Mission 700 Woofer Replacements
Old 2nd January 2013, 01:32 PM   #1
nathanjh13 is offline nathanjh13  United Kingdom
Default Mission 700 Woofer Replacements
Trying to source replacement woofers, as the pic shows the orig was made by Siare model number SPCG3D.
My old man has already tried years ago of taping splits up etc with predictably bad results but say no more.
Tried to contact Mission but the webform doesn't send so Ill try again later. Also contacted ampaholics to see what they have.
I don't necessarily want an exact replacement if something cheaper/readily available will do the trick.
Many thanks for any assistance here, Happy New Year.
Old 2nd January 2013, 08:05 PM   #2
bart_dood is offline bart_dood  United States
re-foam kit?
Old 2nd January 2013, 08:09 PM   #3
linuxworks is offline linuxworks  United States
linuxworks's Avatar
I have that exact same model and my foam rotted out about 5 or 10 years ago. my spkr system was bought new in 1982 or around that time. got lots of years from it and it was my favorite spkr for its size/price.
I also need a refoam or new woofer.
(or, if anyone wants my cabinets and tweeters, I'm open to let them go cheap)
My Photostream:http://www.flickr.com/photos/linux-works/
Old 4th January 2013, 01:51 PM   #4
Thanks but it's the driver that's broken not just the surround unfortunately.
I'm tempted to try and salvage the cabinets and ditch the crossover and see if a full range driver will work, but bow to the forums better judgement first.
If not I'll have a look for a replacement woofer.
Cabinet dims are:
Internal Vol = 11.9 litre (19.5 litre without foam)
External Size = 460 x 260 x 243 (38.5" x 21.7" x 20.25")
Port = 56mm dia wide and 95mm deep, placed 109mm from base edge to its centre point, and 51mm from left hand outer edge to its left hand edge.
I can fill in the woofer and tweeter holes to suit.
Or I can scrap the lot.
Thanks for any advice
Nathan
Old 4th January 2013, 02:34 PM   #5
jerome69 is offline jerome69  France
jerome69's Avatar
SEVENTIES STEREO: Original British Mission 700s Refinished.
Monacor SPH 210
Old 4th January 2013, 03:53 PM   #6
That link is perfect thanks!
I was also looking at adapting the cabinet for some Fostex FF165K as they are higher sensitivity and not too much dearer that the Monacor SPH 210.
thanks again, Im new to speaker building and hate to see old items left ruined really but at over £80 to repair i could prob buy some from ebay and re foam theirs.
converting to full range drives would work perhaps?
Old 7th January 2013, 10:17 AM   #7
Surely the "Fostex box" wooden cabinets from Moldova (on Ebay) are worth the money?
fostex box | eBay
The shipping is a pain mind.
Old 27th February 2013, 06:30 PM   #8
Peter63 is offline Peter63  United Kingdom
Default Replacement woofers for Mission 700s
A few years ago I replaced the woofers on my Mission 700s with Peerless, catalogue number 832737 woofers. A good fit and to my ears sound very good, though, as a bit of a purist I now regret throwing away the originals (the foam surrounds had completely disintegrated) - didn't know that the foam surrounds could be replaced. Good luck.
Old 12th June 2016, 09:04 PM   #9
bloopler is offline bloopler  Belgium
Hello,
I'm trying to find out if my driver is broken on a one Mission 700 speaker I want to restore. The speaker part itself looks in very good shape. The driver itself too.
Still I only hear the tweeter vaguely with no mid or sub at all.
Is there a way to find out which component is "broken" on the driver board?
Sorry for getting up this old thread.
Old 12th June 2016, 11:09 PM   #10
Inductor is offline Inductor  Portugal
Inductor's Avatar
Bloopler, make sure it's from the driver and not the crossover. Connect the faulty () driver to the other speaker crossover and check if it stands.
Mission 700 Woofer ReplacementsHide this!Advertise here!
Mission Cambridge amplifier - Mission Power Amp Module 1 Aleko Solid State 1 18th May 2011 01:14 PM
Vintage AR subwoofer - woofer replacements? midside Subwoofers 0 8th May 2009 03:05 AM
Mission 733 Woofer replacement? vonfilm Multi-Way 11 14th July 2008 07:16 PM
Mission 783 Midrange and 780 Woofer wanted fotios Multi-Way 1 24th March 2008 08:09 PM
mission cyrus II destroyed my woofer roebas Solid State 1 24th May 2004 03:49 PM
