Help - Forgot how to measure coils - Page 4 - diyAudio
Old 11th January 2013, 01:23 PM   #31
mondogenerator's Avatar
lol. I still think its simples to measure DCR and subtract that from a measured Z at a conveniant frequency, then subbing into reactance Eq to find L. checked works test set up and no cap in circuit. Im not sure why a more involved method is required to be totally honest.
Mod: could u pls remove my post no.28? Got befuddled by critics and ended up talking out my rear
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 14th January 2013, 10:03 AM   #32
ODougbo is offline ODougbo  United States
mondo, just a little over my head
However, did go back and make up a new resistor pack with 6 - 8 ohm resistors.
Results were much better, and constant. The 6mH is the only one in question, looks like 6.5mH.
Extra credit if somebody can tell me why the coil starts singing at the measured frequency?
btw, I did order meter - VC6243.
Old 14th January 2013, 01:13 PM   #33
For you builders who might have woofer testers, you can use them to measure inductors (and caps) very accurately with proper calibration.
Below is an example using the original WT2 tester. That coil was taken from a Paradigm 3se MkI xover.
"It's all about the music!"
Help me find cirquit, I forgot where I last saw it? markusA Tubes / Valves 13 23rd June 2011 11:59 AM
Speaker Design... but forgot the name TubeManiac Full Range 1 22nd May 2011 02:37 PM
I forgot what soft ware I used can someone help please? Boscoe Software Tools 3 22nd May 2010 08:00 AM
I am so old I forgot my question, please do not respond ststone Everything Else 0 11th December 2002 05:04 AM
How rude - Forgot to introduce myself! Rarkov Introductions 0 30th September 2002 11:37 AM
Copyright 1999-2017 diyAudio
