Accuton is very expensive. I never see a full three way DIY Accuton.
But you can see : Jenzen-Accu
You will not so far to a full Accuton speaker. The audio tech is a very good driver.
Hello,
I just finished a 3-way with the Accuton C173-6-090 as mid driver:
http://www.diyaudio.com/forums/multi-way/226914-my-refspeaker.html
I am very pleased with the result
Danny
Danny
Take look at Tony Gee's site. Humble Homemade Hifi He has designed 2 speakers using Accuton drivers. "The Humble Statement" and "The Soup Ceramique Mk II". They are archived in his download section. I built a pair of his design using an Eton woofer. Very, very good.
I join Stonehome ;
I had the same idea as yours and was calculating, and searching, prices of the units.Then I was lucky to spot a pair of "Eidoclones" , which were cheaper then the sepatate units. They were "voiced" by Tony Gee ; he did the x-over with very expensive parts.
Also the Eton woofer ; but a bigger one as the one Stonehome uses.
They are very critical about the electronics ; I use a Jungson d88 class A amp.
Wish you good luck on your choises and if I can be of any help ; just let me know.
The DIY-virus stroke again ; now working on a 3-way eton set with a visaton KE25 tweeter ; sounds , at least in my room , better then the "Eidoclones".
