Old 1st January 2013, 03:56 AM   #1
Default L-Pad attenuators
I'm going to build a crossover and add a tweeter to my full range speakers. The tweeters will need attenuating so I was going to make a simple L-Pad with 2 resistors for my 8ohm tweeters.
I then thought that if the tweeter was over or under powering the music, it would mean I would need to change the resistors again. I've seen rotary L-Pad attenuators on eBay and they all say that they are 8ohm. Does this mean each winding is 8ohm?
When using various online L-Pad calculators, a 3dB attenuation requires 2.33ohm series and 19.33ohm parallel resistance. A 1dB attenuation requires 0.87ohm series and 65.7ohm parallel! What is the actual resistance of the windings of these attenuators?
Another project of mine: (a very big one at that!)
http://www.mp3car.com/vbulletin/show...5-pimping.html
Old 1st January 2013, 09:57 PM   #2
It means that the amp/crossover will see 8 ohms. Calculaors will get you in +/- 20% of actual values, I have tested suggested L-pads and they deviate from reality. L-pad is a voltage divider, also, the shunt resistor will reduce the impedance peak at Fs for the driver thus changing the slope and phase of your crossover.
Old 1st January 2013, 10:04 PM   #3
I need an adjustable L-Pad for a 4 ohm speaker, but I cant find any anywhere. The 8ohm version would not work, would it?
Old 2nd January 2013, 10:21 AM   #4
It has different series/parallel resistance values, so no. Why not build an L-pad with resistors? Do some calculations on how much you need to pad, get a bunch of cheap wirewound resistors around these values and build your L-pads.
In another thread I see you`re looking at the XT25SC as a possible option - shunt resistor will decrease the resonance of this tweeter to some extent. The XT25 is around 3ohms DC, get L-pads/resistors after you have the tweeter.
Old 2nd January 2013, 08:32 PM   #5
Hi Mario. Thanks for your answer. The reason I was asking about adjustable L-Pads is I would like to have the option to adjust the tweeter when needed. But I suppose if I size everything correctly and test it, I shouldn't have to do any adjustments, just sit back and listen to them.
Old 2nd January 2013, 08:50 PM   #6
adjustable L-pads tend to oxidize over time, and become scratchy & unreliable. If you do this a lot, it's a good idea to buy just one, solder crocodile clips to it, & use it while setting up the xover. Measure the value of each arm, & replace with fixed resistors.
(although it's not much hassle to tweak a fixed resistor L-pad, you can usually get it pretty good after one or two series resistor changes. I usually use cheap 1/2 or 1 w resistors until I've found the final values, & you don't need to be too precious about the values, e.g. the 3dB example you give above, I'd use 2.2 ohms & 18 ohms, susbtitute the 2.2 with a 2.7 to see how that sounds, & tweak from there)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Burson Attenuators caterpillar Parts 5 26th June 2010 03:21 AM
Attenuators stven Parts 0 12th January 2009 03:05 AM
Attenuators ------ Please Help soundbadger Tubes / Valves 5 13th February 2008 04:19 PM
About Attenuators leiade Solid State 8 3rd November 2002 08:54 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
