Looking for diy active speakers
Old 31st December 2012, 10:14 AM   #11
kumori is offline kumori  Europe
Originally Posted by Ahmad_tbp View Post
whatt ? dsps don t need dacs or dsp based poweramps (what does it even mean) , DSPs usually has 2 RCA input , and 4 or 6 or more RCA output , it has built in DAC , ADC (you can use outside DACs with it but it s an option) and all you need to do is plug it to pc via USB and run the filters on it ,you can connect any RCA to inputs and then connect outputs to ANY power amp you like ...
Ahh, I understand. I didn't realize that there were combined Dac/Adc combinations available yet. Stupid me.
But a diy solution for this would be difficult, I guess.
Old 31st December 2012, 10:45 AM   #12
Ahmad_tbp is offline Ahmad_tbp  United States
no , dsps are growing , in fact that s maybe the reason that active xos isn't that popular these days , you can find some very decent modular DSPs for diying , as I said you only need to connect rca to inputs and cunnect outputs to some amps , then you have to set the filters and that s very easy (you can find some vids on youtube or download the software if available and see how it works) , you still need some measuring equipment if you want to set them accurate , but you can do that buy simulating filters in some other software or do it by ears ,
why DIYing , they r modules available to use in your DIY project and you can buy a very decent and popular one for 100USD , check these out :
miniDSP (cheapest one)
DLCP by hypex (highend)
NAJDA (it s coming soon , it has very good specs and very good price around 300$ I think)
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 31st December 2012, 12:56 PM   #13
Thanks for the info Ahmad, IŽll have a read.
Maybe I can get used to the idea of digital crossovers...
Old 31st December 2012, 01:23 PM   #14
Studio Au is offline Studio Au  United Kingdom
Id second the minisdp. Run a source in and any amplifiers, and you have an active setup. I was using little Class T amps i bought on eBay for Ł25 and they worked pretty well. But you can use any amp, even home cinema receiver ones will often allow 5 channels in one box.
The minisdp can run off a usb plug, I have yet to use it but purchased the digi board and the power amp board (requires you to buy a power supply)
But you can run a 2way active from these two/three small board eliminating the need for separate power amps.
Old 31st December 2012, 01:59 PM   #15
i can understand that , if I could design an active filter with features those DSPs have I would and would never touch the dsps as they have their own downs , but achieving something near those DSPs require a larger setup , lots of knowledge and experience and will cost more ,
Old 31st December 2012, 02:08 PM   #16
john k... is offline john k...  United States
john k...'s Avatar
I would like to go active the "classic" way, by inserting an analoge active crossover after the pre and a second (or third, if it has to be) poweramp and that's it.
John, did you build your speakers on your own?
Yes. My speakers are of my own design and are the equal of any similar systems available.
By the way, with the miniDSP you can set the system up in your "classic" mode, replacing the analog active crossover with miniDSP. My system plans come complete with the required configuration files for the miniDSP if you go the digital route.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 31st December 2012, 04:57 PM   #17
R.I.P.
http://www.hificritic.com/downloads/...RITIC_TRK2.pdf
There is enough information in the above to build an active version.
Use say double the power for the bass than the mid treble.
rgds, sreten.
Old 31st December 2012, 06:03 PM   #18
sfdoddsy is offline sfdoddsy  New Zealand
It's going to be a lot easier to use a digital crossover than an analog unless you are lucky enough to only need a standard crossover with no EQ or adjustment needed.
With analog you are locked into one setup so it better be right. With digital you can easily change if you need to.
Take a look at the number of changes the Orions have gone through on the Linkwitz site. Each change has meant redoing the analog crossover/EQ.
Looking for diy active speakersHide this!Advertise here!
Active filtering or new cross-over for DIY 15 inch homecinema speakers? vandevoordekoen Multi-Way 42 11th October 2012 02:28 PM
DIY speakers using Linn active crossovers? 100decibels Multi-Way 3 4th June 2012 05:06 PM
Need Advice : Adding bass to my existing DIY 2 way active speakers mertol Multi-Way 9 20th January 2012 12:36 PM
mini active amps for diy ipod speakers? Bill poster Solid State 2 23rd March 2011 10:35 PM
DIY Active 5.1 Computer Speakers JamesC Everything Else 1 28th February 2003 01:50 PM
