Help identify these Seas tweeters - diyAudio
Old 30th December 2012, 11:58 AM   #1
DeonC is offline DeonC  South Africa
DeonC's Avatar
Default Help identify these Seas tweeters
Hi guys
I got these tweeters today. They look like they are 35mm domes. I want to use them as replacements for KEF T27 tweeters in a pair of KEF Concerto speakers. One of the T27s is blown, so I am replacing both with these. The pics are below.
Thanks guys,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 30th December 2012, 12:07 PM   #2
StigErik's Avatar
Might be a SEAS H087 ?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 30th December 2012, 12:07 PM   #3
system7 is offline system7  United Kingdom
system7's Avatar
Aren't those the old famous SEAS units that used to be fitted in Dynaco and B&O units in the seventies? They crossed over quite low (1.5kHz) on a single capacitor IIRC.
But I can't remember what they were called.
Best Regards from Steve in Portsmouth, UK.
Old 30th December 2012, 02:21 PM   #4
They are H-087 8ohm units!
Old 30th December 2012, 06:02 PM   #5
system7's Avatar
They (SEAS H087 or Dome H87) were used with a simple 1ohm series with 8uF capacitor and a 0.27mH shunt coil in the BeoVox 2702, which was a speaker I liked. Simple Cap and attenuator in the well documented Dynaco A25.
What is their DC resistance? No-one mentions it. For all that, a very different animal from the KEF T27.
Old 30th December 2012, 08:35 PM   #6
DeonC's Avatar
Thanks, guys. Now I can Google the specs, and then fit them. It will only be a temporary fit, because I found out tonight from a friend of mine that it will be relatively cheap to have the T27 fixed. Problem is the guy that can fix them is a few hundred miles away, so I'll have to send it via post. The Seas will be a temporary stop-gap measure. I just want to be able to match the sensitivity via an l-pad. Then I'll have to figure out what to do with them next. Maybe a Dynaco clone? We'll see. Thank you very much again.
Deon
PS. Someone seems to have measured their DC resistances, because the one has 6-ohm written on the back, and the other 5,9-ohm.
Old 30th December 2012, 09:10 PM   #7
pdul is offline pdul  Denmark
I have just salvaged 2 of those from some old B&O speakers, but it says 3ohm on the units
Old 31st December 2012, 12:02 AM   #8
Madisound archive says 4.6 ohms coil resistance, which sounds about right...
Old 31st December 2012, 12:10 AM   #9
Of course, if I hadn't messed up my first post by saying they were 8 ohms, that would make more sense.
They are indeed 6ohm impedance, 4.6ohm coil resistance.
If you Google seas h-087 then click the 'images' tab, you should find a picture of the spec list fairly near the top- I did...
Old 27th July 2013, 02:38 AM   #10
kiwi88 is offline kiwi88  United States
B+O were 4 ohms
FS - Aurum Cantus G2 ribbon tweeters/Seas 5" excel midrange/Seas prestige 10" omegaslast Swap Meet 13 9th August 2012 09:31 PM
Can anyone identify these tweeters? Ronj Multi-Way 4 11th July 2011 12:16 AM
can someone identify these morel tweeters? terry j Multi-Way 2 27th May 2009 01:10 PM
Seas Millenium tweeters and Seas W22EX-001 sephiroth619 Swap Meet 2 5th March 2007 07:34 AM
New Seas Tweeters ANTHONY2181 Multi-Way 0 15th August 2002 05:47 PM
Copyright 1999-2017 diyAudio
