Garage speakers Low cost important
Old 31st December 2012, 10:42 AM   #11
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
OK What I was thinking won't work.
I get used to being wrong.
Problem solved though as I just found an 8inch full range with a rising response so I guess it's going to be a 1.5Way Baffle is 270mm wide so I guess I'll just add a boost woofer 1st order at ~ the -6dB point somewhere close to 400hz. 2.7 - 3mh should do it
I did say low cost was the priority
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Garage speakers Low cost importantHide this!Advertise here!
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Low space / Low cost B20 Trooper46 Full Range 5 13th September 2008 05:01 PM
High Sensitivity, low cost bookshelf speakers? jonnythan Multi-Way 7 1st March 2006 12:50 AM
How important is sensitivity for near field at low volumes? bluegti Full Range 8 13th January 2006 04:55 PM
garage speakers regal Multi-Way 1 24th September 2004 02:28 PM
