Upgrading drivers
Upgrading drivers
Old 20th January 2013, 10:16 PM   #61
vandevoordekoen is offline vandevoordekoen  Belgium
vandevoordekoen's Avatar
Thank you, inductor!
Yeah, I know, my english 'vocabulary' is not adequate, I'm sorry
I Have to search a lot of words to translate them in Dutch to understand what is meant That doesn't make it easy
Wayne was also helpfull and mentioned that the de250 + H290C needs a 8dB attenuation with my active X-over.
But that I can't just use the components + values of the compensation part of the 4pi crossover: the compensation part is not an individual part, it interacts with the splitter filter. It's more complicated then I thought.
New challenge: finding a filter that simply compensates the de250 (without the complete crossover).
Dumptruck talked about CD compensation on more sofisticated active crossovers. It doesn't sound THAT bad.
However, it's more challenging to make a passive compensation filter that I can put between my amp and de250.
Old 21st January 2013, 03:03 AM   #62
Inductor is offline Inductor  Portugal
Inductor's Avatar
I know. What you said (besides the vocabulary being difficult for you) you already know. (And) That's why a lot of people don't understand, I can assure you. You go to basics with Wayne and that's why. Very down to earth...
You have the high impedance (and compensation) that's going to give you the lift of the high frequency but you add the L-pad (hybrid with compensation) to bring the output down at pass band. It interacts with the 3. order crossover.
If the "de250 + H290C needs a 8dB attenuation" active, do you make the rest 4dB L-pad in a passive configuration? With compensation/cap or without? Does it need to be modeled in SPICE or is it straight forward?
Old 21st January 2013, 11:54 AM   #63
I read a lot on his forum and I understand the basics of crossovers (the top octave compensation, matching the sensitivities of the tweeter and the horn, the highpass and lowpassfilter and avoiding 'nulls').
This link + video, that Wayne sent me, helped me a lot:
AudioRoundTable.com: Measurement => Crossover optimization for DI-matched two-way speakers
However, there is a difference between understanding the basics and making crossovers on your own
I just don't have the time to read read read and try with all sorts of components to get a configuration that sums the drivers perfectly through the crossover region and to make a configuration that compensates the CD on his own.
Would it sound 'disastrous' if I just connect the drivers with the amps (both in phase of course), filtered at 1.6khz with the active crossover, compensating the CD manually by matching the sensitivity of the tweeter before mass-rolloff with the sensitivity of the woofer and compensate the higher frequencies with the treble knob on my preamp?
Old 21st January 2013, 01:02 PM   #64
Inductor's Avatar
Originally Posted by vandevoordekoen View Post
... and compensate the higher frequencies with the treble knob on my preamp?
Clever, that's probably why you have 4dB headroom...
(8+4=12)
Old 21st January 2013, 04:58 PM   #65
dumptruck is offline dumptruck  United States
I don't think Wayne wants his crossovers posted publicly, guys, but is anyone else confused about the resistors? 25Ω in series with the DE250 doesn't work... I must be reading it wrong?
Anyway, you can use 2.2uF and 10Ω (resistor and capacitor connected in parallel with each other, and then in series with the DE250). It's not very elegant, because of the impedance (compare the brown filter curve with my hybrid one posted earlier), but it will work. You can put 16Ω across the DE250 terminals to damp it a little better at 2kHz... that might be just fine after the active LR4 is applied.
Old 21st January 2013, 05:35 PM   #66
Not at all! The link I posted refers to his forum. However, he explains a lot in his forum, if you want to, you can find everything there.
Does the configuration that you propose (2.2uF and 10 ohm resistor + 16 ohm parallel with the de250) give me the compensation (about 8db atenuation) that is needed for the compression driver on a CD horn?
It's that I don't know how to transfer the theory in values and components I understand the goals of crossovers and compensation circuits, but I can't make them myself.
For a good result, do I need to do other things then CD compensation using an active crossover?
Old 21st January 2013, 05:52 PM   #67
Yes, it is -8dB compensation. You would still attenuate the HF level down a bit to your taste with the active level control, as the DE250 sensitivity would end up at about 100dB (with the 16Ω included).
Old 21st January 2013, 05:54 PM   #68
Inductor's Avatar
I have no idea of what you are talking about. In relation to Wayne's work in the passive crossover attenuation it's evident that 12dB attenuation comes from a 25/16 L-pad like it was posted before by vandevoordekoen on post #58.
Old 21st January 2013, 06:02 PM   #69
Inductor's Avatar
vandevoordekoen,
From previous posts I would not regard dumptruck comments as very enlightening, and I would take them with a grain of salt. That's all I have to say. Please follow Wayne's P. suggestions if you want to achieve a successful speaker project. He has all the keys because he has been there.
Old 21st January 2013, 06:12 PM   #70
Originally Posted by Inductor View Post
vandevoordekoen,
For goodness sake, I was simply saying I was having a problem simulating the pi4 high pass, using Wayne's measurements. I didn't mean to imply Wayne made a mistake in his crossover. I've been designing, simulating, building, and measuring exactly this type of crossover for the past year, and I mostly learned from Wayne's writing on CD speakers. If I have made a mistake about something in this thread, please explain what it is.
I don't suppose you are at all interested, but here is the problem I'm getting in simulating the pi4 crossover as it was posted.
Upgrading driversHide this!Advertise here!
Upgrading my lambdas jimbones Multi-Way 0 14th October 2012 01:53 PM
upgrading irfz's AKHeathen Car Audio 8 20th April 2011 01:08 PM
TDA2030 Upgrading livenicely Chip Amps 6 8th November 2010 09:56 AM
Upgrading DM2 beamnet Multi-Way 2 7th December 2007 04:00 PM
