Old 29th December 2012, 10:45 PM   #1
murphythecat8's Avatar
Default a couple of questions concerning my crossover
my crossover is:
For the Tweeter the resistors are 4R7 in series and 6R8 in parallel. Choke is 0.47mH and Capacitor is 1.5uF.
For the Midrange the RC across the driver is 12 Ohm and 4.7uF. The crossover Capacitor and Inductor for the Lowpass are 2.2uF and 0.5mH.
Im using the schematic from this project: http://www.exdreamnet.de/forum/user/.../Pro38_Art.jpg
Thing is, I cant see the Watts requires for my resistors and I cant find the Volts needed for my capacitors. Are the resistors, can I use 1/4watts or 1/2 watts? And is 400v capavitors would be fine here?
can anyone here help me figure this thing out?
thanks
Favorites: Electro:Kettel, Aphex Twin, Arca, BOC, James Ferraro, Simon Posford Jazz: Tristano, Coltrane, Monk, Gil Scott, Miles Davis. Rock: Zappa, Hendrix, Bob Marley, Dinosaur Jr.
Old 29th December 2012, 10:51 PM   #2
Dilletante, tinkerer and beggathoner supreme
Moondog55's Avatar
10 Watt ceramic resistors would be my best guess ( this is what I always use- often 2*5 Watts in parallel )
100 Volts capacitors are usually OK for a 100 watts and anything over that is going to be fine
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 29th December 2012, 10:55 PM   #3
pkitt is offline pkitt  United States
The information shown in your link is way too small to be visible no matter what I try to do to enlarge it, but I can still answer your questions. In a crossover, all resistors usually have at least a 10-watt power rating. Capacitors rated at 400 volts are fine, but so are those rated at 200 volts (and even 100 volts in some cases).
Paul
Originally Posted by murphythecat8 View Post
my crossover is:
thanks
Old 29th December 2012, 11:19 PM   #4
ok so just to be sure, if I use everywhere 2*5 watts resistors in paralel, it always equals 10 watt?
Old 29th December 2012, 11:53 PM   #5
Moondog55's Avatar
Yes IF the resistance of each is the same, it does depend on the tolerance tho, so if you have cheap resistors with +/- 10% one resistor could be +10% and the other -10% and more current would flow through the lower resistance so it will pay to check DCR with the multimeter if doing this.
Also do not forget that the total resistance is equal to 1/2 so you need to double the resistance of each to get the final result you are after
Resistors in Parallel - Parallel Resistor Network
Old 30th December 2012, 01:33 AM   #6
okay thanks, but ill go with Mills. they have 12 watt.
12 W will be fine for my needs right?
Old 30th December 2012, 02:05 AM   #7
Moondog55's Avatar
12 Watts is fine
Greetings and a couple of questions Sasquatch Tubes / Valves 18 10th February 2007 08:49 PM
couple of questions slogan2112 Multi-Way 0 27th June 2004 08:38 PM
a couple questions slackerbob Solid State 1 12th August 2003 02:25 AM
Couple crossover questions dsanders Multi-Way 1 17th August 2001 03:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
