#91 | |
Therefore you can't tell anything about how "audible" this group delay is in comparison to the first, because most of it is caused by a very non-flat amplitude response which will be audible in and of itself. As I said in my previous post, lumping together the audibility of group delay and excess group delay (pano's test has only excess group delay) has been going on throughout the thread and only serves to confuse the issue. The only valid test to determine whether group delay by itself is audible is to maintain identical amplitude responses which means we are really studying excess group delay, not group delay. Any test where we're altering the frequency response to produce group delay proves nothing except that frequency response alterations are audible... Out of interest, try showing us the excess group delay instead of group delay on your bottom measurement, you'll find that across most of the bass region the excess group delay will be relatively flat even in a room, but there may be one or two frequencies where it peaks up really high, typically where there is either a notch in the amplitude response or where the reflections are higher in amplitude than the direct signal...this is useful because it shows us where (with the current speaker configuration and listening position) we cannot EQ out the response error with normal minimum phase EQ...
- Simon Last edited by DBMandrake; 6th January 2013 at 08:31 AM. |
#92 | ||
You can't know what a square wave sounds like until you can produce it acoustically. Real sounds in music all start with causal moment, with minimum phase and very quickly morph to non-minimum phase as rest of instrument starts radiating, followed by immediate environment of instrument. So circle the wagons; compare waveform recorded of instrument, that has been corrected for minimum phase effects of microphone system, and what this sounds like played back on speaker v real instrument. When I analyze my own recording and playback chain, it readily shows minimum phase impact on content <200Hz, providing basis of masking very effect being discussed, even when using expensive headphones. Now here is confusion: Quote:
Points about excess phase are well taken into consideration with corrections I produce. In case of posted sub setup room response is speaker response at listening position. This is excess phase of raw cardioid sub: sub raw excess gd.png In above first big excess phase event is above range of sub. For main speaker measurement and correction due consideration is given, and excess phase between two measurements is adjusted for when integrating filters from different measurements. Fully corrected system is basis for comparison, and I find my setup reproduces waveform of source to much greater fidelity than any uncorrected system I've worked with. |
#93 | |
Take a 2nd order L/R low pass and high pass. Individually they are minimum phase. Sum their outputs together and the amplitude response is perfectly flat however the sum is not minimum phase because there is a 180 degree total phase rotation from low frequencies to high frequencies. It forms an all-pass filter. The excess phase / excess group delay without any change of amplitude response was the whole point of pano's test.
- Simon |
#95 | |
#96 |
where can we see this cardiod subwoofer ? any pictures around there ? what kind of DSP are you using ? (standalone or computer ). |
#97 | |
In any case, given the context of pano's test signal I can't see how there could be any confusion, the result of cascading a high and low pass filter is never going to be an all-pass with a flat amplitude response, which was a key part of the test.
- Simon |
#98 |
What I was attempting to duplicate was a 4th order HP and LP recombined, as they would be in the air. Is this different from combining them electrically or in software?
Take the Speaker Voltage Test! |
#99 | |
So it would be a valid test of the perceived on axis response but probably not of the changes to the reverberant field or early reflections. (since summing in air is only the same as the electrical summing on axis) Early sidewall reflections would only be affected by the changes due to driver beaming mind you, not by differences in delay, so for a speaker with uniform horizontal off axis performance it would be representative of early sidewall reflections too.
- Simon Last edited by DBMandrake; 6th January 2013 at 06:36 PM. |
#100 |
I tried to hear a difference between the 3 files,headphone and loudspeaker.
...nothing. here's the modification on the file it's about 4-5 ms delay below 125 Hz. it's like the woofer is 4.7 fts stepping back. 24 db/oct recombined. ![]() and the group delay modification
| Group Delay | pargon | Subwoofers | 5 | 29th January 2010 07:37 PM |
| Group Delay Correction? | pandaemonium9 | Subwoofers | 2 | 30th December 2007 05:32 AM |
| Evil group delay | phreeky82 | Subwoofers | 16 | 4th October 2007 12:26 PM |
| Group Delay............When Is Too Much Too Much? | OMNIFEX | Multi-Way | 0 | 14th March 2003 07:30 AM |
| Group Delay? | Ignite | Multi-Way | 6 | 13th November 2001 05:52 AM |
