I want to hook up 3 pairs of speakers in my studio, so I can A-B-C my mix. I
purchased a radio-shack "box" that allows me to do this. The problem is my main speakers (near-field monitors) are 4 ohms and the other 2 pairs of speakers are 8 ohms. The instructions that came with the "box" says it can be used with peaker systems that have an impedance of 8 ohms or more. This "box" will allow me to play all 3 speaker systems at once (which I don't want-but it's the only thing I found to connect multiple speakers). I assume this will not work, or do damage to my power amp? ohms ohms ohms.....(mantra) Cheers and TIA Poly http://sonicmusic.net/ |
#2 |
Did it Himself
Can't see why it would be impedance rated, unless it's got a transformer in there. This may be to load the amp with 8 ohms when 3x 8 ohm speakers are connected. I would doubt this though, and if it has such a transformer it will probably degrade the sound as it will be cheap...
Should be fine as long as you only switch on one set at any one time. |
#3 |
Too late...I took it back...wasn't worth taking a chance.
Thanks Poly |
#4 |
frugal-phile(tm)
Yes you have to worry about too low of an impedance for your poweramp. All these in parallel would give a nominal 2 ohm impedance which might cause smoke to escape from your power amp (depends on the power amp)
I've had a few of those switches thru here. That is all they are is switches. As long as you don't turn speakers on such that you go lower than your amp likes you will be fine. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Connecting 8 ohm speakers to a 4 ohm amp | mulliganmaster | Multi-Way | 7 | 1st July 2007 09:33 PM |
| connecting car speakers with home amp | Meteora_LP | Multi-Way | 1 | 15th April 2005 08:33 AM |
| connecting speakers | rs1026 | Multi-Way | 2 | 4th August 2004 03:30 PM |
| Connecting 6 speakers | hjartarson | Multi-Way | 1 | 10th April 2004 02:28 PM |
| Possible? Combining two sets of speakers for computer audio. | UnknownOrigin | Digital Source | 0 | 17th March 2004 01:05 AM |
| Page generated in 0.07379 seconds (74.07% PHP - 25.93% MySQL) with 10 queries |
