Old 27th December 2012, 07:31 AM   #1
diypass is offline diypass  Italy
Default 7-375/32/HEX - C25-6-012 two ways
there somewhere a good sound projsct with these drivers ?
7-375/32/HEX
C25-6-012
thank you
Old 27th December 2012, 03:36 PM   #2
Inductor's Avatar
It's a pity if you don't find a response to your project, but they are really nice drivers. In what stage of the project are you? They don't seem that difficult of a DIY project to finish, nice drivers with a easy/fair/smooth output. You probably can go with a classic crossover from the tables, not very problematic and adjust later for better results, more like a classical 2-way. You can use also a standard box/cabinet for the Eton driver. I can also give you the best size volume for that driver if you ask for. The method I would use, if not using modeling software, starting with a crossover/box for the Eton 7-375/32HEX and then calculating the right/best crossover (@same) frequency for the tweeter Accuton C25-6-012.
drivers pdf's
http://www.etongmbh.de/uploads/tx_pb..._375_32Hex.pdf
http://www.accuton.de/media/datashee...0C25-6-012.pdf
projects enclosure/crossover for the Eton
https://www.intertechnik.de/Shop/Lau...xtra1=&extra2=
https://www.intertechnik.de/module/1385034.pdf
https://www.intertechnik.de/Shop/Lau...,de,7271,48297
2 examples from Strassacker: Lautsprecher - Boxen - Selbstbau
recommended cabinet 1:
closed cabinet with 4,1 L volume
from 95/60 Hz (-3dB/-8dB)
recommended cabinet 2:
13 L volume bass reflex cabinet
with HP50 reflex tube, 15 cm long.
from 51/40 Hz (-3dB/-8dB).
another project for the Accuton C25-6-012 tweeter
DiyForum.net :: Läser ämne - Behöver lite hjälp med Högtalarbygge.
The tables can give you a starting point before your finished project. You can also adjust for small attenuation if needed with the tweeter. That gives you a nice project either you use simulation software, mics/measuring equipment or just your ears.
A second order should work fine with +/-2K2 crossover, I don't see any problem.
Old 28th December 2012, 08:03 AM   #3
thank you, but is not what i'm searching.
Old 28th December 2012, 12:20 PM   #4
Inductor's Avatar
Ok, do you mean you need a finished tested project?
Old 28th December 2012, 12:23 PM   #5
yes
Old 28th December 2012, 12:58 PM   #6
maartentje's Avatar
How about a Avalon Transcendent clone.
I have the drivers but no time at the moment to build them.
Martin
Old 28th December 2012, 01:05 PM   #7
should be fantastic!!!
i well use only one 7/735/32 hex for each box
PE:Sony 299-012 Clearance: Line array? Kahooli Multi-Way 5 21st September 2011 02:47 PM
Eton woofer 8-480/32 HEX gormish123 Multi-Way 1 23rd February 2011 01:59 AM
Eton 7.3 drivers for sale (ER4 and 7-375 Hex) Jed Swap Meet 5 14th March 2007 10:12 PM
c25 cap in '59 Bassman ReIssue otokomae Instruments and Amps 4 13th September 2005 03:14 AM
Eton 32 Hex woofers Jimmy154 Multi-Way 8 12th February 2004 10:34 AM
Copyright ©1999-2013 diyAudio
