Tweeter CD wave guide
Old 26th December 2012, 12:14 PM   #1
Audiodidakt is offline Audiodidakt  Norway
Default Tweeter CD wave guide
Robert C White / Rod Elliot have a DIY wave guide design instruction here:
Practical DIY Waveguides - Part 1
(part 2 and 3 of the guide is linked at the bottom)
I have tried to work the formulas into an Excel-spread sheet using the 1500 Hz example in part three, but cannot get the formulas/numbers right: I do not get the same numbers as White / Elliot:
If we make angle α = 90 ...
c = ( 720 + 90 ) / 5 = 162
b = 360 - 324 + 90 = 126
W = 1 / 3 * (( 25,306 (126 * 162 + 90 * 162 + 90 * 126 )) / ( 1500 * 90 * 126 * 162) = 142mm
The horn radius is...
R = ( W - t / 2 ) / sin ( α / 2 )
... where t is throat diameter and α is the radiation angle. Throat diameter is determined by the tweeter used, and must be measured carefully. The overall depth is ...
d = R - (Tan a / 2) ( w - t / 2 )
The radius at points x is ...
r ( x ) = ( t / 2 + ( w - t ) / 2 ) - ( R - ( m + d - x ) )
... where m = Tan α / 2 ( 0.5w - 0.5t ) and t = throat diameter. x is the centreline distance along the waveguide from the throat in millimetres.
x R x R x R x R
0 18.5 6 25.2 12 34 18 47
1 19.5 7 26.5 13 35.7 19 50
2 20.6 8 27.8 14 37.6 20 54
3 21.7 9 29.2 15 39.7 21 59
4 22.8 10 30.7 16 42 22 71
5 23.9 11 32.3 17 44
Table 1 - Offset (x) for various values of R
Are the formulas above incorrect, or do I just have to look more into my excel-formulas? I get the numbers corret to "w" (expect I get 0,1418 istead of 142), but after that White / Elliot do not sum the formulas for R, d and r(x), so I do not know in which formula (R, d og r(x)) my mistake(s) are.
Have anyone made a spread-sheet for designing CD wave guide / Cd horn?
Best regards
Gisle
Old 26th December 2012, 01:08 PM   #2
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
I can provide you with one of a variety of waveguide worksheets that are available. Can you open an excel spreadsheet?
If yes, pm your e-mail address to me and I'll forward it to you.
This one is based upon Geddes' oblate spheroid profile.
Old 26th December 2012, 10:00 PM   #3
DogStar is offline DogStar  Europe
I think your "mistake" is the number 25,306. In your spreadsheet you should use the number 25306. Notice that in the US they don't use the comma the same way as we do in Scandinavia (or many other European countries). Apart from this detail, your computation looks ok. The following formula (in Excel) gives you the number directly in mm:
= 1000*(1/3)*((25306*(126*162+90*162+90*126))/(1500*90*126*162))
Good luck with the number crunching.
Cheers David
Old 27th December 2012, 09:22 AM   #4
Cheers David
Aha! Suddenly I blushed... Thanks!
And also thanks to Ed for email.
Old 27th December 2012, 11:54 AM   #5
In case you are not aware of his work, Dave Pellegrene is thermo-forming waveguides.
acoustic waveguides
http://techtalk.parts-express.com/sh...ght=pellegrene
Tweeter CD wave guideHide this!Advertise here!
Ribbon Tweeter Wave Guide removal? deanxxx Multi-Way 5 4th April 2012 05:14 PM
Ribbon Tweeter Wave Guide removal? deanxxx Parts 0 4th April 2012 03:40 PM
Short Tractrix tweeter wave guide domtw Multi-Way 3 3rd May 2009 04:05 AM
