Woofer suggestions for horn loaded 3 way - diyAudio
Old 25th December 2012, 07:45 PM   #1
Default Woofer suggestions for horn loaded 3 way
Well, I have finally gotten the performance of my little system to the point that I can say that the last thing left is the bass and low bass. The "satellite" consists of a 100hz bandpass horn running a B&C 12PE32 woofer, and a TAD 4002 on a stereolab 250hz horn. Right now, I'm running the low bass on a Totem Lightning sub, and its having a hard time keeping up, to say the least.
So, here's what I need: A bass system that will cover from 100hz down to as low as is feasible, I would LIKE it to be horn loaded, in keeping with the system theme, but that is not mandatory. I want a larger driver- 15 inch or more, because I'm pretty well convinced that the larger drivers are the way to go for truly high dynamics.
I have a pair of Faital 15 inch woofers from my TL project that did really well, so they may end up being pressed back into service, but are there any other suggestions?
Combination of Back-loaded Horn and Fron loaded horn?! ARIYAHOOR Full Range 26 1st June 2012 09:20 PM
Front loaded and back loaded horn DrWoofer.com Subwoofers 0 3rd August 2007 06:55 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
dual woofer horn loaded bass bin trespasser_guy Multi-Way 23 23rd December 2002 09:50 AM
Need help with horn-loaded sub slicemaster101 Multi-Way 26 17th September 2002 01:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
