Recommendation for a crossover choke - Page 3 - diyAudio
Old 25th December 2012, 04:22 PM   #21
Originally Posted by wintermute View Post
Actually after looking at the values of components in the crossover in the first post, I wonder whether they are correct. The lpad resistors seem to be pretty close together in value, and 1.5uF is an awfully small value!! What is your intended crossover frequency?
Tony.
5khz.
I'm using the pro-38 with a audax pr170mo driver crossover design...
Old 25th December 2012, 04:27 PM   #22
Originally Posted by pdul View Post
It is more important to maximize the quality of the 1,5uf capacitors.
Just my 10 cents.
ok, so the 1.5 uf cap is the most important in ym crossover? I plan on using mundorf m-cap, but if you say its the most important cap, I shall go with the supreme for the 1.5uf...
so in your opinion, I could go with the 7$ coil and it shouldnt influence much the sound? 0.47mH 18AWG Air Core 0.32 ohms DCR Coil 1281 0.47mH 18AWG Air Cored Induction Coil [3140] - $7.50 : SpeakerBug, capacitors, inductors, resistors, crossover parts, speaker supplies
Old 25th December 2012, 04:30 PM   #23
I wouldn't call ~$17 a very expensive choke esepcially since it has a DCR of 0.16ohms which is decently low.... yes you could go with the 20ga one at $5.00 but it has a DCR of 0.47 ohms, which I would think will start to make a difference. But obviously there is a point of diminishing returns
Attached is the sim from my crossover for my mtm's. The shunt coil is in a 3rd order network, and is 180uH and had dcr of 87 milli ohms. If I increase the DCR to 470milli ohms I get the blue curve. It may not look that significant but the is 10db more energy getting through to the tweeter at 100Hz with the higher dcr coil. That is what Simon, and Lynn in the thread I linked to are saying is really bad. In a second order (electrical) network the difference may be greater.
Tony.
Very interesting. To be honest, I have the money to go with the 4x 17$ coil, but I have to ask, what about if I go in-between the 5$ coil and the 17$. the 13$ 0.47 mH 15AWG Air Core 0.20Ω DCR 1518 Induction Coil 15 AWG .47mH Induction Coil, Inductor, Air Core, crossover [2625] - $13.20 : SpeakerBug, capacitors, inductors, resistors, crossover parts, speaker supplies looks like a good option? But if you believe that it will affect the sound, I will not hesitate and will spend 20$ more, not a big deal!
Old 25th December 2012, 09:31 PM   #24
pdul is offline pdul  Denmark
The in between coil seems like a good option combined with as good a capacitor as you can affort, since its in series with the tweeter. If you have a series resistor, then use a non inductive 7-10 watt
Old 25th December 2012, 11:56 PM   #25
wintermute's Avatar
Yes the 15 gauge one is a good option as it is only marginally higher DCR than the 14Ga one. As I said you reach a point of diminishing returns.
The problem that can manifest with high dcr shunt coils will generally only be noticable when the speakers are driven hard (ie high volume levels) and is an unpleasant distortion from the tweeters. So if the speakers will not be run at high levels then it is probably less of a concern.
I wasn't sure about the values in the crossover as 1.5uF seemed a pretty small value but 5Khz is a quite high crossover point, also is the tweeter horn loaded? that would make a difference too Also if the tweeter is much higher sensitivily? I thought that the resistors would create quite a high cut lpad. do you have links to the speaker I googled pro-38 but didn't turn up anything
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 26th December 2012, 04:42 AM   #26
ScottG is offline ScottG  United States
Those last few sources were from Australia.. shipping to Canada would be absurd.
Expensive:
Jantzen 0.47mH 16 AWG Copper Foil Wax Coil 255-508
Cheap (but still good):
Jantzen 0.47mH 18 AWG Air Core Inductor 255-228
(..and you can always "pot" it yourself.)
Middle of the Road:
Jantzen 0.47mH 15 AWG Air Core Inductor 255-408
(..again, pot it yourself.)
perspective is everything
Old 26th December 2012, 11:53 AM   #27
wintermute's Avatar
yes I wasn't suggesting that he should purchase them from Aus (the "something like this" was supposed to indicate that), I was just demonstrating some options for good quality reasonable priced coils I probably should have said to try and source something similar locally.
Tony.
Some of my photos
Old 26th December 2012, 01:11 PM   #28
Pano is offline Pano  United States
Pano's Avatar
Get a Jantzen from P.E. (see above) or buy the choke from Solen Canada. Easy, peasy.
www.solen.ca
Old 26th December 2012, 02:54 PM   #29
Expensive:
Middle of the Road:
that is really kind, thanks for the research, I'll take the middle of the road just to be sure and I hope it will be okay.
this is the project. http://www.exdreamnet.de/forum/user/.../Pro38_Art.jpg
Old 26th December 2012, 03:25 PM   #30
Pano's Avatar
Are you using this fro L1 or L2? See the DCR of the coils in your project.
You can find what you want in either Jantzen or Solen to match the DCR.
26H choke good enough for a grid or anode choke? speakerfritz Tubes / Valves 7 2nd December 2011 07:05 PM
Help replacing a PSU choke - How to choose choke Hubba Tubes / Valves 2 10th September 2010 03:33 PM
Crossover Spec Recommendation for DYNAUDIO Drivers??? speedemon Multi-Way 2 9th June 2009 04:59 PM
recommendation for variable crossover (wtb) hum4god Subwoofers 3 2nd February 2008 04:13 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 09:30 PM
Copyright 1999-2017 diyAudio
