Recommendation for a crossover choke
Old 25th December 2012, 06:47 AM   #11
ScottG is offline ScottG  United States
Originally Posted by murphythecat8 View Post
please somebody help
you should be looking at inductors for speakers, not electronics. Small inductors for surface electronics have very low current capability.
partsconnexion, madisound, parts express speaker section, etc..
perspective is everything
Old 25th December 2012, 08:06 AM   #12
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
something like this will do the trick... 0.47 mH 14AWG Air Core 0.16Ω DCR (Coil 10) [2810] - $16.68 : SpeakerBug, capacitors, inductors, resistors, crossover parts, speaker supplies
But I second Sreten on the winding your own if you are on a budget. You can check out my blog if you decide you want to go down that path
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 25th December 2012, 11:04 AM   #13
pdul is offline pdul  Denmark
From your explanation of your crossover, i noticed that the coil you are talking about, is in parralel with the tweeter, and if thats the case, the DCR is not that important really
Old 25th December 2012, 11:17 AM   #14
allmost any crossoverchoke at 0,47mh will do
Old 25th December 2012, 11:21 AM   #15
just another
wintermute's Avatar
Ah that is actually a common misconception. In fact the DCR in shunt coils on tweeters IS important. The lower the better. The reason being that it is the LOW frequencies that you want to be shunted off (as you don't want them distorting and intermodulating your tweeter), so if the DCR is high then those low frequencies can't pass so easily and the coil does not do it's job as well as intended. This post http://www.diyaudio.com/forums/multi...ml#post2605112 has the reasoning behind this.
Tony.
Some of my photos
Old 25th December 2012, 11:22 AM   #16
It is more important to maximize the quality of the 1,5uf capacitors.
Just my 10 cents.
Old 25th December 2012, 11:29 AM   #17
Yes but within reason. The guy said low budget, and combined with the fact, that its already filtered thru a 1,5uf cap. It has to be a very expensive choke to make any percieved difference.
Old 25th December 2012, 11:55 AM   #18
just another
wintermute's Avatar
I wouldn't call ~$17 a very expensive choke esepcially since it has a DCR of 0.16ohms which is decently low.... yes you could go with the 20ga one at $5.00 but it has a DCR of 0.47 ohms, which I would think will start to make a difference. But obviously there is a point of diminishing returns
Attached is the sim from my crossover for my mtm's. The shunt coil is in a 3rd order network, and is 180uH and had dcr of 87 milli ohms. If I increase the DCR to 470milli ohms I get the blue curve. It may not look that significant but the is 10db more energy getting through to the tweeter at 100Hz with the higher dcr coil. That is what Simon, and Lynn in the thread I linked to are saying is really bad. In a second order (electrical) network the difference may be greater.
Tony.
Some of my photos
Old 25th December 2012, 12:00 PM   #19
just another
wintermute's Avatar
Actually after looking at the values of components in the crossover in the first post, I wonder whether they are correct. The lpad resistors seem to be pretty close together in value, and 1.5uF is an awfully small value!! What is your intended crossover frequency?
Tony.
Some of my photos
Old 25th December 2012, 01:51 PM   #20
ODougbo is offline ODougbo  United States
There is a swap meet page - whata got to trade?
Good quaitly .47 chokes would not be hard to find on DIY.
hi
I need two 0.47mH chokes. They need to be aircore and decently low DCR. I have a small budget. Any recommendation?
Recommendation for a crossover chokeHide this!Advertise here!
26H choke good enough for a grid or anode choke? speakerfritz Tubes / Valves 7 2nd December 2011 06:05 PM
Help replacing a PSU choke - How to choose choke Hubba Tubes / Valves 2 10th September 2010 02:33 PM
Crossover Spec Recommendation for DYNAUDIO Drivers??? speedemon Multi-Way 2 9th June 2009 03:59 PM
recommendation for variable crossover (wtb) hum4god Subwoofers 3 2nd February 2008 03:13 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 08:30 PM
