Tannoy K3809 - hardened cloth surround issue - solved
Official Court Jester
Joined 2003
I'm lazy , so there are excerpts from my correspondence on Tannoy Yahoo group; all quotes - Mighty ZM :clown:
I'm putting this here as future reference for some other desperate Tanner ; I must admit ( or I'm just boasting ) - I'm always having serius backup for all things speakers - from Aleksandar RAAL ....... even if I'm always stubborn and I'm bugging him only post hoc ..... to be sure that I didn't blew something :rofl:
K3809 - cloth surround impregnation solvent ?
as I wrote - pair of K3809
cloth surround , no back cone ribs
Fs is high - around 70Hz on both drivers
I contacted Tannoy Support , but they can't help - all they can recommend is
reconing , which is out of possibility , counting on fact that drivers are in
excellent condition and just slightly used (well - same as they aren't used at
all )
so - anyone having real life experience , regarding solvent for surround
impregnation ?
whatever , guy at Hasling Audio Systems Denmark is doing exactly the same for SH
Altec's , so I think same is possible for Tanns
TIA
Tnx for reply ;
There is no particular info on Altec related link , but point was that planned
procedure was implemented ...... I sent e-mail to Danish guy , asking for his
recipe , if nothing else , as starting point .
Whatever - K3808 (3809) are having impregnated cloth surround , not paper ;
that's visible on many pictures on net , and "cloth surround" is having exactly
that name in related info
In any case , if I succeed in "operation" , I'll share my findings
of course - "Danish guy " wasn't prepared to share his recipe ; I don't blame him 😉
that's why I'm sharing mine :rofl:
besides Sam R's problem with teared surround ......... and strictly speaking of hardened cloth surround - I'm stubborn and there is no way I'm going to change them .....
I would go to generic soft (probably acquired from Sonido guys in Hungary )
cloth surround , but will ever never invest money in new cones or - God forbid!
- neoprene surrounds 😉
I remember some guys at Diyaudio speaking of
2-Butoxyethanol - Wikipedia, the free encyclopedia
so I plan to start with that
Hardened cloth surround problem solved !!
soaking both sides of surround , using small brush , with plain Ethanol 95-96% ,
brought Fs from 71Hz to 29Hz .
I'm expecting that Fs will rise to spec. 35Hz , when solvent evaporate
That's what we are calling just Pure Alcohol , and you can buy it in every
drugstore.
So much speaking of recone and surround replacement 😉
I'll keep you informed , of course ;
even in case that Fs start rising again , I'll just repeat procedure , removing
old impregnation as much I can , and brush new tacky layer above it
then it will permanent solution
no damage , certainly ;
I'll post few pics in few days , after having definitive conclusion about
longevity of cure
Update : after 24h rest and solvent evaporated - two steps forward , one step back 😉
steps forward are :
1 - impregnate is not brittle and cracked (inducing noise , especially
detectable at Fs)
2 - everything looks just nice , almost as new
step back - Fs is back on 71Hz 😉)
whatever , I'll proceed with more cleaning of old impregnate , and then try to
seal it with tacky surround goo , which will (hopefully) prevent repeated
hardening
will keep you informed
OK
K3809 - cloth surround impregnation solvent ; hardened cloth surround - high Fs
- issue SOLVED
procedure finished and confirmed
after 24h (and more ) of solvents evaporating , Fs is still good : 33-35Hz
RECIPE
what you need :
1.small brush , semi hard m ~8mm wide , same as kids are using for painting in
school
2.Ethanol 95% (pure alcohol)
3.Acetone with oil ( nothing else than nail polish remover )
4.mouse glue (yes , that organic everlasting sticky goo)
5.Vaseline
6.cotton cloth ( old T shirt or whatever)
brush - buy it anywhere , mouse glue - anywhere , everything else - nearest drugstore
important to say - surround was originally threated from upper side , mostly ;
just slight residue of original rubbery impregnate is visible from bottom side
of surround
procedure for upper side of surround:
using brush - from upper side - soak surround with ethanol ; it's best to soak
it in parcels of 10cm , then rub it with same brush ; whenever you fill brush
with residue , wipe it on cloth
repeat procedure until you make two full circles (so entire surround perimeter
is twice treated)
move to second speaker ,same procedure , again two circles ;
repeat same soak-rub-wipe-soak-rub-wipe procedure on both speakers , until you can see clear fabric of cloth , without any trace of rubber
it's fun , but only if you have some muzak and coffee 😉
after few steps in procedure you'll see what's happening ; if you think that
you'll gain anything with another soak-rub-wipe circle , just do it
leave speakers 12h , to let Ethanol to evaporate
now - put some mouse glue on small (coffee cup) plate , add acetone and dissolve it to something liquid as milk
using brush - put that mixture on upper side of surround ; if you see that your
mixture on plate is going firmer , add acetone and mix ; when you treat entire
surround , take just acetone with brush and treat entire ( already impregnated )
area with it , to make it more uniform
leave it for 12h
now - bottom side of surround :
soak brush in acetone , rub it firmly in Vaseline , then put that mixture on
entire bottom side area ; goal is to have tiny layer of vaseline on bottom side
leave it 12h
measure Fs
easiest way of measuring Fs - use sine signal generator with 50R output
impedance , connect it to bass terminals , put CRO probes on terminals
sweep frequency from 100Hz down ; when you see biggest sine amplitude , there is Fs
another possibility for measuring - instead of sig gene - use Sig Jenny program
( wave gene with counter ) , sound card to small amp , amp to bass terminals ,
AC voltmeter to terminals
put few volts of sine to bass , sweep from 100Hz down , when you see biggest
reading on Vac meter , that is it
mine are at 31 and 33 Hz , I'm not loosing sleep because of using mouse glue and
vaseline on piece of cloth 😉
then one guy is saying that Mouse Glue is forbidden in some EU countries ; my reply :
in that case - just buy softest surround impregnation goop ; easy to do on line
, if living in Europe
unfortunately - Serbia , where I'm living - somehow isn't in Europe , so I'm
Paypal-less 😉
that means that I'm just lazy to chase soft surround impregnation goop from
Europe , taking in account that there is no domestic one
then guy asked where to search for surround impregnation goop ;
my reply :
sorry - just google ;
search for something like this : Speaker Repair Adhesive, Sealer, Cloth Surrounds, Foam Surrunds, MI-1291
but , it's wise to buy only after confirmation from seller that really soft
thing is in question
Zen Mod
then guy asked for difference sound-wise , pre and post procedure ; my reply :
sound-wise - taking in account that my pair is most mint pair I ever had
opportunity to even see (except surround condition - most probably as result of
no-usage for all long years ), I'm eager to say that they're sounding just as
proper pair of K3809 😉
right now being in stage of preparation of making boxes for them , I'm having
fresh experience just listening them in bafle-less iteration ; even like that ,
there is proper difference in bass , comparing to prior (surround treatment )
performance
whatever , fact that plain and common Ethanol is sufficiently good as solvent
for old impregnation , was nice surprise ....
Zen Mod
I hope you enjoyed little story :clown:
In case that I remember to get cam to my workshop tomorrow , I'll make few pics and put it here , along with few pics of same drivers prior to fun procedure
as I promised - pics ;
here :
Tannoy K3809 - hardened cloth surround issue - solved - diyaudio.rs
index.php
Hi Zen Mod,
My 3808's have hardened surrounds and I've been looking for a solution. Found the Tannoy Yahoo group discussion - and, surprise, it’s you. 🙂
This must certainly be worth a try. I think I'll go with 'normal' goop.
Has fs stabilised now, i.e. not climbing again?
Thanks for sharing!
pics are tellin' everything 😉
feel free to use mouse glue
so called original thing is worse than that - butyl based goop vs. organic goop
whatever - if you want regular (commercial) thingie - try it first on piece of cloth
after few days check compliance
zen mod
the next time you have a driver with a stiff surround or spider assembly try using Kodak photoflow diluted 8:1 with water.i've used this time and again on old stiff drivers with excellent results.and unlike solutions with volatiles that evaporate you don't need to consequently re-apply.
i'm currently doing this to a batch of HX-125 drivers out of a pair of Biffrons Hox 05's
tnx for tip !
I hope that I'll not need that in future ....
not for my K3809 ( I'm not doubting durability of my tweaks) , but for any other ...... 😉
edit : just to be sure - you meant this ?
Kodak Photo-Flo 200 Solution should be added to the final wash when processing black & white films. It acts as a wetting agent by foaming up and protecting the film from dust and scratches while hanging to dry.
Decreases the water-surface tension on the emulsion.
Minimizes water marks and streaks on film.
Promotes faster, more uniform drying.
