#21 | |
It's very important to consider the baffle step in a crossover design. But in case of your woofer it's better not to model the box effects. Why? The frequency response of the driver is measured in a Seas test cabinet having almost the same baffle dimensions (310x210 mm) as your cabinet. Thus the measurement published by the manufacturer already includes the baffle step. Don't do it twice! |
#22 | |
THIS IS NOT INTENDED AS A FINISHED CROSSOVER Woofer second order electric 1 mh coil 7.8 cap Tweeter third order electric 12 mfd = 10 mfd + 2.2 mfd in parallel in series .15 = .18 mh parallel to ground 90 mfd electrolytic or 80 mfd electrolytic plus 10 mfd plastic bypass to sweeten it up a bit. I would never put an electrolytic in series but in this case it's parallel and probably won't have any ill effect since it will be passing very little signal. Bypassing it with a good plastic will reduce or eliminate any harshness. L-Pad Series 7.5 Ohm resistor Parallel 8.5 Ohm resistor As you can see from the plot I have a ways to go to get the slopes the way I want them but phase is tracking over most of the usable range. The woofer phase crosses the tweeter about 200 Hz and track it till about 6K, but I can do better. I just didn't put the time into this version because I'm going to re cut the baffle. My version won't have any BSC and for sats you probably won't want any either. I'll get better measurements when I can set up over at the shop where we have a 40' ceiling. Tom
"Scientific discoveries arise through discourse" -Grissom Last edited by Siggma; 7th January 2013 at 02:21 AM. Reason: explanation |
#23 |
David Griesinger, top engineer at Lexicon, made the point in one of his papers that the lower in frequency you go, the more effective side or rear channels will be at creating a sense of envelopment. That suggests that the side or rear speakers should have a good lower mid and bass response. Personally I've found that side speakers up at the ceiling, half way between the listening position and the front speakers, aimed directly across at each other sounds real good to me. I found that full surround gets tedious to listen to after a while with music, so I don't bother with those.
#24 | |
I'll load this up tonight at home and have another look. I really want to see if I could make a whole family of units from the same tweeter and woofer to give me a 5 speaker set up, if that is possible. |
#25 | ||
As for the alignment, I was wondering about orienting the units with the tweeter and woofer in the horizontal plane, so the dispersion will be wide vertically, but narrower in the horizontal plane. The reason would be that they will be located higher than ear level, and I can rotate the speakers easily around the vertical axis to point at the listening position, and then I would not have to rotate them to point down. |
#26 | |
I feel like I have just finally entered the world of proper bass, after building a sub, and I'm currently working on the basis of buildling complementary speakers to work down to the sub. I'm currently experimenting with the crossover frequency, 80 Hz seems to work well with my current two way main speakers, although the 60 Hz frequency discussed in the paper as a target is perfectly possible to use, if I can design the rear speakers to work that low. Thanks for pointing this out to me! |
#27 |
in surround arent the rears already high passed at the decoder? i always thought they were. Or are you using THX? i dont wish to criticise but if they are HP'd at the decoder, then your efforts may be wasted.
It still amazes me every time I get something right |
#28 | |
I like the finished Visaton HT, very revealing tweeter for it's size and that little woofer has very nice bass but I found a really good deal on the Aurum Cantus so I bought 6 of them. I'll be using the Vifa XT25TG30 for the AC-130's. The Aurum Cantus is much smoother and crossed down low will have excellent off axis response with that tweet. I bought mine on eBay and he probably won't ship out of country. He's in California. Holler if you decide to go this route and I'll post the final crossover. If you do decide to go the Visaton/Vifa route the boxes need to be .25 for .7 Q, I'm using a .23 and the roll off is so close it's nearly identical. Tom
"Scientific discoveries arise through discourse" -Grissom |
#29 | |
With the AVR300 you can also choose to send the unfiltered signal to either the front, or all of the speakers if you want their crossovers to do the work, and you can also set it up to use the sub channel for HT but just use the front speakers for stereo signals, if you have full range main speakers. I can't help but think this feature is also for those whose subs play explosions better than music. |
#30 | ||
| Lexus is 300 rear speaker setup | ToyPick | Car Audio | 27 | 12th July 2012 03:13 PM |
| Cheap 2-way Speakers - Design advice | jacobthellamer | Multi-Way | 26 | 13th May 2012 09:15 PM |
| trying to figure out a cheap sub setup | AutoAudio | Subwoofers | 14 | 6th December 2005 01:09 PM |
| Cheap low power design for computer speakers | haut | Solid State | 2 | 5th March 2004 04:47 AM |
| searching software to switch front speakers to rear and rear to front!-dolby surround | MCM | Everything Else | 6 | 6th February 2004 09:29 PM |
