Design for a cheap two way for use as rear speakers in 5.1 setup
Old 7th January 2013, 09:57 PM   #31
DrNick is offline DrNick  United Kingdom
Originally Posted by Dissi View Post
Just a hint:
It's very important to consider the baffle step in a crossover design. But in case of your woofer it's better not to model the box effects. Why? The frequency response of the driver is measured in a Seas test cabinet having almost the same baffle dimensions (310x210 mm) as your cabinet. Thus the measurement published by the manufacturer already includes the baffle step. Don't do it twice!
I've had another look, and if I use the Response Modeller to extract the phase, but do not add any box effects, on the basis that this data was taken for a 10 litre box, I can adjust the crossover and get this as the final response
which seems +/-1 dB from 100 Hz to 10 kHz and then has a hump up to +2 dB to 20 kHz. At the bass end the response falls off from 100 Hz and is 3 dB down at just under 80 Hz.
Just to be clear, I've used the box model for a 7 litre box with the correct T/S parameters to generate the impedance curve, not the one from the specs, which is for a driver with no baffle. I take it this is the correct procedure?
The crossover for the woofer is third order electrically
L2 2.00 mH, 0.2 Ohms
C2 15.00 uF
L3 0.50 mH, 0.2 Ohms
With a parallel leg over the woofer containing C 20 uF and R 10 Ohms.
The tweeter has a third order section
C9 15 uF
L9 0.2 mH 0.2 Ohms
C10 25 uF
with a series resistor 2 Ohm after the crossover, and parallel resistor over the tweeter of 2.5 Ohms.
The null with the tweeter reversed is
So, thanks again to Dissi for pointing out there were already baffle step effects in the Seas published response curve. I think this is now back to looking feasible for a rear channel design. The drivers would cost 66 each for the Seas U16RCY/P, and 23 each for the SB Acoustics SB26STC-C000-4, so this should be within budget if I don't get carried away on the crossover parts.
So, per speaker, for the woofer section
2 mH solid cored 0.18 Ohm about 5 (JANTZEN-5152)
15 uF cap, about 5 (Solen 15.00uF 400V DC Polypropylene Capacitor)
0.5 mH air solid cored 0.2 Ohm about 6 (JANTZEN-1267)
10 Ohm, 10 W ceramic 0.60
20 uF cap, about 6 (Solen 20.00uF 400V DC Polypropylene Capacitor)
and for the tweeter section
0.2 mH 0.2 Ohms, air cored 1 (JANTZEN-2078)
25 uF cap, about 7 (Solen 20.00uF 400V DC Polypropylene Capacitor)
2 Ohm and 2.5 Ohm resistors, 10W ceramic 0.60 each
for a total of 36.80. Bugger, that's more than I was expecting.
Allowing 10 for materials for each cabinet (mainly the cost of epoxy glue) this gives 135.80 per speaker. Not too far over budget, but if someone was to get excited about fancy caps you could almost double it, they are all quite large. I would be interested if anyone has suggestions for decent but cheap capacitors other than the Solens, or if anyone can confirm if they should be fine.
Old 7th January 2013, 10:31 PM   #32
Bob Richards is offline Bob Richards  United States
Bob Richards's Avatar
Originally Posted by mondogenerator View Post
in surround arent the rears already high passed at the decoder? i always thought they were. Or are you using THX? i dont wish to criticise but if they are HP'd at the decoder, then your efforts may be wasted.
Some decoders probably do cut the bass, citing that most side or rear channel speakers are going to be small (wife acceptance factor) and not able to go very low in freq. Most bass is mixed in mono too. It wasn't until I read many of the David Griesinger papers that I realized that you really do want stereo bass, and as much bass as is practical on the side and rear speakers. Griesinger is one of the best in the world. All his papers are worth the time to read.
Old 7th January 2013, 11:12 PM   #33
Siggma is offline Siggma  United States
Siggma's Avatar
Originally Posted by DrNick View Post
I'm just playing with spreadsheets at the moment. I'm just beginning this!
I've been fiddling with speakers for years, even decades but only recently got equipment to take measurements so I'm pretty new too. What you did so far looks great, but factory data is probably not going to work on the actual driver. Many woofers have their T/S parameters measured at 2.83 volts which violates the entire premise of "small signal parameters". Recently I purchased a TC Sounds EPIC that measures fs 31Hz but it's advertised at 24 Hz. It's impedance slope is different than what I measured as well. When I run the voltage up I get 25Hz fs and .40 Qts which is close to advertised, and that was with few hours on it. The Visaton in this project measure higher fs than spec even after break-in but again, run the voltage up to 1.5 or so and it measured correctly. What they tell me is that it more accurately represents the driver "in-use", which may or may not be correct. It does make sense on a large woofer like the EPIC where the surround is thick but not on that little 5".
So you have built a pair with the Visaton drivers?
Yes, I've got them in my kitchen. Waiting for some parts to arrive so I can go cut new baffles. Probably tomorrow. I cut the tweeter hole too high on the baffle. It reduces baffle diffraction effects but messes up vertical axial response. See image below.
Can I ask what you use for measurement equipment and software?
I first bought a Dayton Audio calibrated mic and registered a copy of ARTA/LIMP/STEPS. I bought a sound card with phantom power for the mic but I don't know the amp gain. I recently measured it at full output and it's quite low (30) but at least I can take accurate SPL measurements. LIMP is good for impedance curves and to test inductors/resistors/capacitors but you need to make a "jig" or get some 1% resistors for reference. I bought a jig off here. It was a project someone made then he left and we haven't heard from him since. It has a reference 10 ohm resistance on a push button switch and a built-in TDA2030 single chip amp so I don't have to have a big nasty amplifier sitting on my desk. It has separate probes for amp and impedance measurements. I also use it to take impedance measurements but I had to make an external impedance probe. I also use it for listening tests, it's a clean little amp putting out about 4 watts with the power supply I have (1 Amp 24V)
I also have an Omnimic. It's a USB based mic and software for acoustic testing which is nice because it run on a laptop. It comes with a calibrated mic and very good software and you can use the mic in ARTA. I haven't figured out the preamp gain yet. It has a preamp that is part of the mic and they don't publish the data. They do publish the mic sensitivity though but I'm not genius enough to figure it out.
I think I'll need to invest in some testing equipment if I'm going to do this properly.
I'd invest only if you're going to be using it to do more than a single speaker system. There are several places here within 10 miles of me that will do acoustic testing for me. I'm thinking of advertising to take measurements for people if I can find a good place to do it. I would either need to make a closet sized anechoic chamber or get some really tall speaker stands. Anechoic chamber sounds easier than a 15' tall stand for both speaker and mic.
Easiest thing there is for acoustic testing is Omnimic. But you can purchase a Behringer calibrated mic for under $100 online and either make or purchase a calibrated preamp. If you go the cal mic route make sure you either know the preamp gain or that it has calibrated gain settings. Then you can use ARTA/HOLM Impulse/ Speaker Workshop or one of the other free or mostly free programs for taking measurements with a sound card. I've found that most sounds cards are decent enough for good measurements. Mine has a low noise floor (over 60 db) and only has slight roll off at 5 and 18.5K. If you want really accurate measurements you can make a .cal file for ARTA that includes the sound card FR and phase compensation. Mine would only need a few samples for calibration, 3 or 4 on the bottom to account for the roll off below 10 hz and maybe 10 or so points to account for the HF roll off on the top end. You'd have to manually combine the sound card calibration with the mic calibration to get it correct but that's easy in Excel or Openoffice Calc. ...Anyway...
For impedance you can use the unregistered copy of LIMP, a sound card and a 1% reference resistor. No need for calibration. It uses the "constant voltage" method of measurement that requires no calibration except the reference resistor. It uses the sound card output (up to 2 volts) to measure T/S parameters but on some drivers you need an amp and external resistor to get the necessary voltage. All you really need is to know the exact resistance of your reference resistor to get accurate results. I forgot to add that the sound card probably doesn't give as accurate results because the impedance back to the sound card it so high whereas the impedance of the amp is quite low, below 100 ohms for sure. Point is if you're going to take impedance measurements you'll need a at least a small 5 watt or large amp.
Well, this is getting way too long. Hope I've helped.
"Scientific discoveries arise through discourse"
-Grissom
Last edited by Siggma; 7th January 2013 at 11:40 PM. Reason: Added amp recommendation
Old 8th January 2013, 10:41 PM   #34
Siggma's Avatar
I got the parts today and cut the new baffle. Got the second woofer breaking in and the flat-pack boxes I need to finish the project. I have the other tweet and some more crossover components coming in a day or two but I think I have enough parts to flesh out the final crossover. At least I can get the values I need and do a listening test with two speakers. I might need to adjust things depending on the DC resistance of the inductors.
It should be easier to get off axis response to be more even now. I'm still deciding if I will flush mount or not. I don't think it's going to make that much difference on this speaker plus with the drivers surface mounted like the picture the Z axis is nearly zero. This woofer has recessed screws and a rolled edge so it's edge is very smooth. It's only 1/4" high too. The tweeter lip is only 1/16th" so it will have very little diffraction effect. Don't know if it's worth the trouble.
Opinions?
-Grissom
Old 8th January 2013, 11:33 PM   #35
Siggma's Avatar
There are some good articles on how different components act in terms of insertion loss and how they effect overall sound. Insertion loss is only part of the issue though. Generally speaking inductors cause the biggest issues as they are, in fact, simply coils of wire. But the wire size (12 vs 18 gauge), type (OFC or not), shape (square, triangle, flat), coil shape (round, toroidal, tubular) and DC resistance all have an effect on the final inductor. IMHO, the inductor is by far the most important component in a passive crossover. Caps induce very little resistance or insertion loss. Neither do resistors. Inductors, on the other hand, can make or break a crossover. Most digital crossover designers make some basic assumptions about inductors and in general assume they are purely inductive. I'm looking for the article I read a while ago that really opened my eyes to inductors and their contributions to a finished speaker system. I'll post the link when I find it.
But you were asking about caps. I think much of the hype about caps is just that, hype. While there is a difference between an electrolytic and a plastic cap and while we used to use Mylar caps and don't much anymore, I don't see the real value in paying $45 or so for an "Audiophile" capacitor. I doubt you'd hear the difference in most cases unless you're in a very quiet room and are under 30 in age. I shop at Parts Express, Madisound or Radio Shack myself.
-Grissom
Old 9th January 2013, 12:32 AM   #36
Opinions?
So this is the Vifa BC25SC06 and the Visaton W130S! I like the fact that the tweeter is sat back more, and should be closer to the woofer centre. As to the mounting, I had a pair or JBL LX33's back in 1989 (my dad still has them, they've not gone far) which had rolled metal edges to the drivers like those, and they were not recessed, but there was a thin (3 mm or 1/8") layer of grey foam rubber round the driver that the edges compressed into to form an airtight seal. Might be do-able for these? If you got a square of it you could fit it up the tweeter too and then that would fit almost flush to the foam, plus I believe the foam is better than meeting an edge with regard to diffraction of the treble? Image from (http://www.hifidatabase.com/)
Are these going to be redeployed now that you are working on the Aurums?
Nick.
Old 9th January 2013, 03:31 AM   #37
Siggma's Avatar
The woofer was about 21mm behind the tweeter when measured using PCD and Jeff B's Z axis process. It will be at least 1/2" closer to zero now which is around 12 mm. Phase should track closer together over the entire range and be easier to line up with a 2nd on woof and LR4 on tweet but sometimes it's difficult to get phase to track if they are too close to zero. I'll have to fiddle with slopes but the goal is to prevent the woofer phase from crossing the tweeter phase at all. I know there is some math behind figuring this out but it's beyond me at the moment. I won't know until I take measurements and start to model it. Probably tomorrow afternoon if I can find a place to run the router for a few minutes. I live in an apartment and wouldn't even think of running that thing in my house. But there are storage lockers downstairs about 10'x10' that would be acceptable. I might just go out on my porch tomorrow and finish the routing I need to do so I can spray the panels with Quiet Kote to deaden the panels then glue up the cabinets.
Nick.
I was originally going to make 5 of them but put that idea on hold when I found the other woofers. I don't know what I'll do yet. I might sell them to a friend who's never owned an audiophile speaker, give them to my son as a gift (if he promises not to torture them with his digital amp) or sell them on Craigslist after I paint or cover them in veneer.
I'm thinking ahead but only working on one project at a time. I have to finish these first or I'll get all messed up. I have a test enclosure for the Aurum Cantus but I haven't cut the baffle yet. I'm probably going to try the Vifa XT25SC90 (small 40 watt neo version of the larger 90 watt Vifa and ScanSpeak Discovery R2604/8320 1" Tweeter Ring Radiator) with it first. It won't cross down at 1.5K with that little neo tweet though. The XT25SC90 has an fs around 700Hz but the Scanspeak has an fs around 450 Hz so it should cross down low much easier. However, just because they got the fs lower doesn't mean it will handle more power. It's still rated about the same but Scanspeak has modified the resonant cabinet for a lower fs which means lower distortion. I've been told there are better tweeters to use so I haven't decided yet. Could use the Dayton Audio Silkie or its aluminum cousin or even the ScanSpeak Discovery D2608/9130 1" Textile Dome HDS Tweeter which is said to be a better sounding tweeter but it's $80...
I modeled the new position using the old sweeps and it looks better already. Phase tracks much closer over the spectrum. This will be a decent little speaker.
Tom
-Grissom
Old 9th January 2013, 02:59 PM   #38
Siggma's Avatar
Nick.
I usually put a bead of silicone around the edge to make a gasket and to help seal but now I have 1/8" foam tape just like what you describe. Parts Express also has foam and other acoustic panels you can purchase for not too much. I'm also going to spray the interior of these enclosures with acoustic damping spray. An alternative is to use a panel of damping foam. I'll also place a little bit of acoustic stuffing in each box. I don't tack it to the sides, I just place it loosely in tbe enclosure behind the woofer. It's only there to break up the mid range back wave from the woofer, not to alter the enclosure effects. It should reduce any mid range nasal effects from standing waves.
That's a diffraction panel to reduce baffle diffraction effects. It may reduce diffraction but it also reduces efficiency to some extent. I think I'm going to try it without flush mounting. As long as I don't see peaks and dips in the response curve it will be fine. I could also model it in Jeff B's diffraction simulator. I don't know if it will model diffraction effects on the surface of the baffle though. It's easy enough to run the router over the opening after the box is glued up so it's not a huge deal. Are you thinking of this pair up as a possibility? Can you get these drivers at decent prices?
-Grissom
Old 9th January 2013, 04:46 PM   #39
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
DrNick - RE Post 31.
That looks great. Nice cross over point. Good driver integration. Very flat response. Relatively simple cross over. Just to be clear though, you did enter driver offsets? Woofer z should be something like -0.025 if using the newer version of PCD. The older version should be 25.0 or something iirc.
This shouldn't make a terrible difference, it's probably fine.
Old 9th January 2013, 07:38 PM   #40
Siggma's Avatar
Yes I did. My earlier Z axis measurement was wrong. The mic moved between measurements when calculating Z axis so the phase was off a little (measured with mic on carpet). The correct Z offset was -.022. The old z offset was -.022 and the new offset I guessed at -.012 but was wrong too, it should be -.01565 (22 - 6.35 [1/4"] = 15.65 mm) based on moving the woofer 1/4" forward.
I changed the offset and used the existing measurements. It won't be exactly correct because the new woofer measurement will be more off axis than the original but it's not by very much. I measured both drivers on tweeter axis and used the phase data from Omnimic directly. When I get the crossover installed I'll reverse the tweet and double check the dip. If it matches both depth and frequency I'll know I have valid phase data and subsequent phase tracking. If not I'll try again. I want to go back and use ARTA and try out the "minimum phase" measurement. When you take the measurement with ARTA you select the same number of samples (gate time) for each driver making sure to get the correct point on the impulse response where the signal just begins. Then you select a frequency response display and make sure phase is displayed. Then select "minimum phase" and the phase displays as a wavy line. If I am correct the "minimum phase" conversion begins with zero phase and includes only the phase delta rather than absolute phase. It should be easier to use since there would be less 180 crossings but I'm not sure if my surmise about minimum phase is correct. Can't seem to find that specific information.
This next set of measurements are going to be taken outside on my porch. I live in a second story apartment with laundry below me. The porch is 15' off the ground. If I set the speaker on the edge of the railing and the mic 1 meter away, on the porch, I should be able to gate down to 90 Hz, maybe even lower. Assuming the first reflection is the floor of the porch or the building behind the mic the floor is the closest object about 8' away. There would be nothing behind the speaker for over 100' and nothing below for 20', only the porch in front and the 2" railing its sitting on. It will definitely be better than indoors as long as I average till it's stable. 5-7 is usually enough averaging but I'll have to see. Over averaging makes the FR slowly drop downwards. Not sure why yet.
As for flush mounting the woofer I probably won't. I already cut the hole and the woofer has a rather large 3/4" lip. I'd have to either buy an expensive 1 3/4" rabbet bit and remove the bearing or plug the hole with a scrap, clamp it all down and use a straight bit and the circle cutter. If I don't get it perfectly centered it will be out-of-round and look horrible. The time to rabbet the opening is before I cut the hole. I do it this way: First I set router buddy to a 5 3/4" circle, straight bit depth to 1/4" and make the rabbet, then set the circle for 4 1/4" and cut progressively deeper till I'm almost through. The last 1/32" I leave attached, punch out the plug and use a straight panel trim or chamfering bit to finish the edge. I do need to chamfer the inside and round-over the front baffle before I glue it on though. I'm looking at a reconditioned Ryobi router table with vacuum port and all the fences/guides/external wiring for $79, including a year warranty. I can't pass it up but I don't have a place to put it... yet.
-Grissom
Design for a cheap two way for use as rear speakers in 5.1 setupHide this!Advertise here!
Lexus is 300 rear speaker setup ToyPick Car Audio 27 12th July 2012 04:13 PM
Cheap 2-way Speakers - Design advice jacobthellamer Multi-Way 26 13th May 2012 10:15 PM
trying to figure out a cheap sub setup AutoAudio Subwoofers 14 6th December 2005 02:09 PM
Cheap low power design for computer speakers haut Solid State 2 5th March 2004 05:47 AM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 10:29 PM
Copyright ©1999-2017 diyAudio
