Zaph SR-71 On-wall?? - Page 2 - diyAudio
Old 26th December 2012, 07:02 PM   #11
Thanks Sreten. I'm trying to imagine what You've wrote in Your first post. Language is still a little barrier for me. Could You please draw a simple sketch of what You think would be the best idea?
It would be much appreciated
Old 26th December 2012, 08:00 PM   #12
diyAudio Member RIP
Its a cabinet with angled side walls around, e.g. with 45 degree walls,
a 200mm x 350mm front baffle and an overall depth of 100mm the
rear baffle would measure 400mm x 550mm. You can square off
the rear of the cabinet a little to reduce the rear size.
rgds, sreten.
Old 27th December 2012, 08:43 AM   #13
ODougbo is offline ODougbo  United States
@sreten,
Q. It might get a bit crowed in the box with the xo (which is somewhat large), if the xo is mounted elsewhere - how long can the 4 (each) wires be? E.G. could they be next to the amp and run 12' wires.
Tehtoril - I think your best bet is to move the port(s) to the bottom, you may have to use two smaller ports flanking each other.
Old 27th December 2012, 01:06 PM   #14
So, You mean something like this:
Old 27th December 2012, 02:31 PM   #15
I think that is it -
BTW - you could still use existing boxes with mods.
Old 27th December 2012, 03:36 PM   #16
Nah, too much work - my SR-71's are floorstanders
I'd rather make whole new cabinets :]
Old 27th December 2012, 11:38 PM   #17
Are they the same as pic in post #13? (send a pic).
btw, looks like you can fit PVC ports behind dowel if you come up from the bottom (again post 13).
Old 28th December 2012, 10:15 AM   #18
They're not as good looking as Yours, cause I haven't finished the visual side (guess I got too lazy after first listening test:] ).
Altough, they are fully assembled and 100% working :]
I'll try to make a pic and put it here after work.
But right now I'm in a middle of rebuilding my future apartment, so I already paid an advance to the best cabinet-carpenter in my country.
He's my guarantee, that it will be solid, fast and like-good-furniture-looking
Old 28th December 2012, 10:52 AM   #19
Belt Sand and Formica them.
btw, you can make a slot port with the same volume/area of the existing port.
Make it the same volume of existing port - fill them with sand if you want to double check the volume.
The ploy here is the the slot can fit behind the woofer.
Zaph SR-71 vs. Proac 100 Scrappersa Multi-Way 1 5th March 2013 05:35 PM
LTB: Zaph SR 71 daveandjenny Swap Meet 0 30th March 2011 04:29 AM
Looking to buy 1 Zaph SR 71 daveandjenny Swap Meet 0 6th February 2011 10:15 PM
Zaph SR-71 question FickleBJT Multi-Way 7 7th August 2010 12:52 AM
PDX Zaph SR-71 Build Thread StewLG Multi-Way 194 4th May 2008 02:11 PM
Copyright 1999-2017 diyAudio
