Old 4th January 2013, 10:21 PM   #21
buzzforb's Avatar
GM,
You got cab dimensions on this one. Stilll have a pair of 414's to pair with 806's
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 5th January 2013, 05:03 PM   #22
GM
AOT = adjust on test
" Well, the MLTL is a simple to design/build/tweak, higher sound quality [SQ] vented alignment, so hard to go wrong with it IF it meets the needs of the app" Your statement corcerns me, what is the downside of the MLTL ? ( My assumption was if the onken works for me then should be similar with better LF, based on your comments.
Just reading into what your saying, i just make the cabinet as big as possible with a TL around 62" and tune the port to get what i want.
Would it not be possible to use a non rectangular cabinet ...
Whats the issues with expanding MLTL as i have seen a number on the web, and lends itsself better to the cabinet shape i propose.
I need to get MJK software up and running so i can simulate, i assume port location and room effects need to be accounted for?
Have some particle board i was goint to knock up a test cabinet, so i can experiment with port and driver location etc. Can initially make a simple rectangular cabinet to see how the MLTL integrates with the horns, so a good starting point would be appreciated.
I noticed someone putting a Karlson type port on their MLTL i assume that this is not the right thing to do?
On the topic of cleaning the altec surrounds - is a tooth brush to stiff to move the doping around with?
Old 5th January 2013, 07:55 PM   #23
I don't think literally "as big as possible" is going to be right for a 414 - you'll run out of excursion eventually.
Old 5th January 2013, 10:13 PM   #24
That was a figure if speech, obviously if space wasn't an issue, i would probably be considering a front loaded horn. I am wondering if something like the Edgar "show horn" may be an alternative to whats being discussed. With my space constraints this would be limited to around 45 hz, assuming i get help from the corners of the room.
Old 6th January 2013, 10:59 PM   #25
GM is offline GM  United States
GM's Avatar
Originally Posted by buzzforb View Post
GM,
I already posted all the pertinent dims except I forgot the vent location, which is
~12.2" up from the back bottom.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th January 2013, 09:49 PM   #26
Do we take it as a 48" long column, CSA = 288 inches, with the vent 12.2" from the bottom, if so, sorry i missed where the driver is located from the top then.
Old 28th January 2013, 07:57 PM   #27
Got around to measuring the 414'z. Using the -6db approach i got the following for one of the drivers
fs=38hz qms=3.0 qes=0.25 and qts=0.23 Vas=160 ltrs Re=11.2 ohms ( the VAS determined this using a closed volume, adding weight method gave me 466 ltrs - quoted Altec spec was 256ltrs so not close with either approach.)
Not as close as i was expecting, but then again they are 47 years old. I may try cleaning the goop off the surround and then remeasure to see what changes.
Old 7th June 2013, 07:38 PM   #28
Long time doing other things, starting to look at the cabinets again. Managed to get the fs down to 35hz by cleaning the surrounds with some MEK (well really redistributing it). Started looking at the MLTL cabinet again for these drivers. Managed to find my account details for MJK's site and software so was going to try replicating GM's simulation in Mathcad, unfortunately my student version of mathcad doesn't seem to load anymore, and don't feel like paying out again for it.
Reason i wanted to simulate it isn't i wanted to second guess GM but was looking at making the cabinet a little taller @ 36" ( better for the TPL) and was going to attempt to work out what i needed to change. I was going to keep Vb the same and adjust the CSA down accordingy for the extra 4" of height.
Initially my throughts are to knock together a simple cabinet from particle board adding the flexibility to move the port location so i can fine tune.
One thing i was musing with is can the Decca corner horn approach of having reasonant cabinet panels to damp the harmonics as suggested by Ralph West be used to minimise internal stuffing used with MLTL's or is this an idea from the 1960's best ignored?
Old 8th June 2013, 02:59 AM   #29
Exclamation freebie TL software
Tho not as accurate as MJK's speadsheets, Transmission Line v.3.6.1.14 does a nice job. Known to be accurate from ~80-200Hz. Above 200 the resonances are greatly lifted in amplitude and below 80 response is reduced by 6-8dB @20Hz. Take this into consideration and it works quite well.
Here is the diy thread
Old 9th June 2013, 12:49 PM   #30
Thanks for that. I tried loading it, without success, issues loading the MS framework needed to run it. This could be why my copy of mathcad doesn't work. May ask one of the offspring if i can borrow one of their more upto date laptops (that i bought anyway) and see if it works on that.
My Woofer Cabinet: Altec TAD JBL HP8903B Multi-Way 30 9th January 2013 03:37 PM
Amplifier for Driving Altec 414z's vinylnvalves Multi-Way 9 1st May 2012 06:45 PM
Name that Altec lansing Cabinet dwhitf Multi-Way 0 29th January 2011 05:23 AM
FILTER cabinet VOTT ALTEC sigurd Multi-Way 0 15th July 2009 11:16 PM
What is This cabinet enclosure? Altec? superjunk Multi-Way 0 21st April 2009 03:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
