Cabinet Design for Altec 414z's
Old 7th July 2013, 09:57 PM   #101
vinylnvalves is offline vinylnvalves  United Kingdom
The tuning isn't really doing anything currently - you wont hear the hump in their current state as the roll off is around 20db at 40hz.
Room acoustic is solveable - a local home cinema room company for a price will come and do a survey and tell me how much to fix it with lots of foam etc.
I am glad i am being the example of how not to build a MLTL.
Whats happened to yours Buzz - was wanting to see if yours worked first time!
Old 7th July 2013, 10:53 PM   #102
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Doubtful, as I know less than you and depending heavily on modeled response. My current choice is here. screwed up start point of port, but doesnt change much. I like the idea of downward firing port, but it has been suggested that this not feasible without significant lift off the ground to reduce floor interaction.
Altec Lansing
...Shape the sound , Man!
Old 8th July 2013, 03:41 AM   #103
GM is offline GM  United States
GM's Avatar
Well, everything I’ve seen still comes up a leak and to answer my earlier seeming conundrum, I’d forgotten that this is a folded pipe, so a leak between the two pipe lengths around the divider board satisfies it.
Also, if the divider board isn’t long enough, i.e. doesn’t preserve the area expansion around the bend, it can at least partially be the cause when the driver is at the top of the bend.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th July 2013, 03:46 AM   #104
GM's Avatar
Define 'significant'. IME, the larger the cab's base area, the less gap required due to a greater slot radiating area.
GM
Old 8th July 2013, 08:08 AM   #105
buzzforb's Avatar
GM,
Thanks for the answer. The port would be 6" in diameter and base would be appx 24"x25". Sim looks good to my eyes, being bested only by much larger cabinets or ones with driver positioned 1/2 down length. Talking about ideal, positioning the driver 1/2 way down the TL is quite shocking in what it does, but practical layout is difficult in my mind.
Old 8th July 2013, 01:25 PM   #106
GM's Avatar
You're welcome!
FWIW, I get a 2.55” slot assuming there’s at least 6.68” clearance to any walls, otherwise it would become an empirically arrived at gap for me, but historically I use slot loading to further mass load the vent or make up for a too short cab acoustical pipe length, so no experience trying to find a 2pi loading solution to a 1.0 or 0.5pi boundary condition or even know if there’s one in theory.
Hmm, to my way of calculating it, ~half way is only 'ideal' in a golden or acoustic ratio cab or typical expanding TL [ML-horn, AKA MJK's ML-TQWT project].
Usually not difficult if folded, but folk's generally not tolerating a wide baffle severely limits design options too much to make it practical.
GM
Old 8th July 2013, 01:45 PM   #107
buzzforb's Avatar
ill post the worksheets later if you dont mind taking a look.
Old 8th July 2013, 02:45 PM   #108
buzzforb's Avatar
When you say 2.55" slot, is this assuming no internal port length and using floor to create this slot.
Here is 30% driver placement
Old 8th July 2013, 02:48 PM   #109
buzzforb's Avatar
Here is 50% of line length. Sorry Vinylvalves, if GM helps me sort this, ill happily let you get a laugh or two at my expense.
Old 8th July 2013, 09:46 PM   #110
A sectio through the test cabinet showing how the speaker is located with respect to the fold.
Cabinet Design for Altec 414z'sHide this!Advertise here!
Amplifier for Driving Altec 414z's vinylnvalves Multi-Way 9 1st May 2012 06:45 PM
Name that Altec lansing Cabinet dwhitf Multi-Way 0 29th January 2011 05:23 AM
FILTER cabinet VOTT ALTEC sigurd Multi-Way 0 15th July 2009 11:16 PM
What is This cabinet enclosure? Altec? superjunk Multi-Way 0 21st April 2009 03:14 PM
