Speakers For Heavy Metal ? What Matters ? - Page 4 - diyAudio
Old 23rd December 2012, 03:25 PM   #31
mortron is offline mortron  Canada
Originally Posted by Ahmad_tbp View Post
you should take a look at this :
FLESHGOD APOCALYPSE - The Violation
must metal genres doesn't contain classical instruments or anything other than guitars,bass and drums + vocals , but there are lots of them that contain ! even nile sometimes use some other instruments as well
Nile apparently uses human bone flutes or did at some point... Whether or not folklore, it's a great tale.
Old 23rd December 2012, 03:29 PM   #32
Saturnus's Avatar
Thanks for the link. Pretty cool.
Old 23rd December 2012, 03:31 PM   #33
Something like this:
http://profesional.beyma.com/ingles/pdf/15LX60V2.pdf
http://profesional.beyma.com/ingles/pdf/8P300Fe.pdf
http://profesional.beyma.com/pdf/CD10FeE.pdf
http://profesional.beyma.com/ingles/pdf/TD194.pdf
Would cost 130 + 56 + 36 + 30 =252 +vat here in the UK (bluearan.co.uk) but
$326 + $170 + $150 + $100 = $746 (462) (prices from usspeaker.com).
The UK prices seem a bargain, the US ones not so much. No idea what the Oz prices would be.
There seems to be quite a lot of good looking cheap drivers coming out recently from Beyma and Faital and may be others. Not sure how well the prices travel around the world though.
Old 23rd December 2012, 03:35 PM   #34
dewardh is offline dewardh  United States
Go to a metal concert (take earplugs). Look at the speakers the sound is coming from. That should be enough of a hint . . .
Old 23rd December 2012, 03:40 PM   #35
Up your budget - get a Nao Note - Metal music is one of the more complex genres -
you need quick bass = active crossover
need clear mid bass = dipole mid bass
I got a Nao Note - totally no regrets - clear metal music and heavy rock no distortion even at low volumes
Old 23rd December 2012, 03:43 PM   #36
Last time I looked it was the same ubiquitous line arrays where the sound of every other PA user comes from. Genre doesn't really matter any more, only the amount of cabs and amps varies a bit.
Old 23rd December 2012, 06:21 PM   #37
nigelwright7557's Avatar
If it is very heavy metal you needs loads of bass.
Quite often heavy metal guitarist tune down their guitars to get lower notes and get a heavier sound.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 23rd December 2012, 06:38 PM   #38
Saturnus's Avatar
Yeah but guitars don't go that low even tuned down to C# (3 half notes down) as Black Sabbath and most doom and much death metal is. That's still only a 69.30Hz fundamental frequency. Almost no information at the fundamental anyways. Most is in harmonic distortion.
Old 23rd December 2012, 07:50 PM   #39
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
dont forget you will have phase issues at rolloff
low end roll off is no different from any other crossover point in that respect
another point is you will probably use vented BR tuning
and maybe even high Q tuning
but you know what happens when hitting it with notes below the tuning frequncy
I dont expect you would quit everything above 8000hz
even if that would make more sense
I guess it will be no surprice when I suggest a closed box design, maybe apperiodic to have some venting
Old 23rd December 2012, 08:21 PM   #40
Ummm . . . yep . . . and what does that tell you (apart from that line arrays are replacing horn-and-reflex cabs almost everywhere)? Those line arrays are part of the sound. If you don't have them you don't have it.
So what's Your Heavy Metal name? pinkmouse The Lounge 38 14th September 2016 09:12 AM
Heavy Metal berkshirejd Music 65 4th February 2011 06:55 PM
Heavy Metal distortion. Stormrider Instruments and Amps 7 7th February 2008 09:52 AM
Copyright 1999-2017 diyAudio
