#21 | |
Altecs and GPA's may be relatively common in the USA but they are all but unavailable in OZ and their weight makes overseas shipment unviable. I know there are Eminence based Karlson designs but the 'results unknown' factor is too great for me to take a chance with someone elses money. Don't misunderstand, I really appreciate your idea. In a year, when I have some Karlson under the belt, I may be more willing to take a punt. I hope you are around with your suggestions then! Kind regards, potkettleblakk |
#22 |
I would slightly disagree. Complex metal of the scandinavian variety can be played perfectly well on a well designed 2 way. If you need deafening volumes and really want to feel the double kick then a 2way will run out of steam.
It still amazes me every time I get something right |
#23 |
Not up on modern Metal but I remember recordings with a lot of Ambience and dynamic compression so I'd be thinking of a system that is smooth through the midrange and dosent become shouty and stays balanced with high volume..
Just my 2 cents, Joel |
#24 | |
![]() besides...the music itself distorts plenty enough on its own wont hurt one bit to take away a little of it
#25 |
#26 |
I cant think of a serious metalhead who would be happy with a dome midrange and a planar. Would be good for some kinds of music, but go crank some Nile through it and see how happy it makes you.
And no, metal doesn't contain harpsicord or violins ...or keyboards. |
#27 |
I'd lean towards a 12"+horn 2 way or a 15"+6-8"+treble horn depending on budget and requirements myself and seriously consider going active.
Beyma has some good looking new (at least to me) drivers which are cheap here but some cost more than double on US sites. |
#28 | |
http://www.faitalpro.com/products/fi...atasheet_8.pdf |
#29 | |
Btw, my username is taken from Danish doom metal legends Saturnus. http://www.myspace.com/saturnus Last edited by Saturnus; 23rd December 2012 at 03:02 PM. |
#30 | |
FLESHGOD APOCALYPSE - The Violation must metal genres doesn't contain classical instruments or anything other than guitars,bass and drums + vocals , but there are lots of them that contain ! even nile sometimes use some other instruments as well
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
| Heavy Metal | berkshirejd | Music | 65 | 4th February 2011 06:55 PM |
| Heavy Metal distortion. | Stormrider | Instruments and Amps | 7 | 7th February 2008 09:52 AM |
| So what's Your Heavy Metal name? | pinkmouse | The Lounge | 18 | 20th June 2006 08:38 PM |
