#121 |
btw, I designed this Onken style sub for a fellow member...he already had the woofer
Beyma SM-112/N Enclosure Help |
#122 | |
The drivers in the Elsinore I use have Low Dynamic Compression and this translates to high volume without fatique and for midrange it's a wonderfull thing. Joel |
#123 |
I think one could narrow down metals problem area even further to low mids.
There is an awful lot going on there: Bass harmonics/distortion, guitar fundamentals, voice, toms, snare and depending on eq the fundamentals of the larger cymbals. In combination with heavy compression a tour de force for any speaker and the poor bugger who has to mix that. ;-) One of the reasons I never liked mixing metal, so easy to turn that region into a mud bath! Especially if your heart isn't in it because you don't actually like metal… If he goes with a 10" co-axial (did I get that right?) I would look at a 15" to cross in at somewhere between 175 and 250Hz as a starting point. |
#124 |
Would you please show me an example of a good metal mix?
#125 |
post #100
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
#126 | |
So if you had a 15" on each side, sure, the crossover could be higher than a typical subwoofer. If only 1 sub, then higher crossover could still be OK if it is between the speakers. |
#127 |
Yes, I do mean active since I always mean active and because crossing passively that low is just too expensive when using quality parts.
Personally I never really liked mono subs, I very much prefer a proper 3way to 2+1. Not least because it allows you to cross higher and so remove some stress from the mid range driver. It also cleans up the lower mid/upper bass region which I find important especially with metal. |
#128 | |
) room.
| Heavy Metal | berkshirejd | Music | 65 | 4th February 2011 06:55 PM |
| Heavy Metal distortion. | Stormrider | Instruments and Amps | 7 | 7th February 2008 09:52 AM |
| So what's Your Heavy Metal name? | pinkmouse | The Lounge | 18 | 20th June 2006 08:38 PM |
