Old 25th December 2012, 03:25 PM   #111
Originally Posted by Moondog55 View Post
Yes it is and all sold out here in OZ
I always thought Paul was loosing something by not using the 12 inch in the Tarkus
but it is designed more for a sealed box and Paul likes to build ported I think
Bass depth versus reasonable box size is probably why the 10" is preferable.
Value too I imagine. Bigger is not always better at reduced SPL's, YMMV.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 25th December 2012, 03:33 PM   #112
winslow is offline winslow  United States
Bigger is always better if you have the room for it.
Old 25th December 2012, 03:42 PM   #113
picowallspeaker's Avatar
No it isn't
Why ?
I really don't know
Old 25th December 2012, 03:56 PM   #114
tinitus is online now tinitus  Europe
when it comes to a woofer, and thats whats being questioned now, I cant imagine it will ever get too big but the box can get too big
Old 25th December 2012, 10:05 PM   #115
Dilletante, tinkerer and beggathoner supreme
Moondog55's Avatar
I believe the OPs client has made a decision or at least narrowed down the options
( Personal communication)
Personally I like big woofers but as Tinitus says box size vs room size is always an issue and often the main one these days
OT but relevant We are looking at buying a house and we looked at one last month Huge room set up as HT; 80 inch TV and some crappy "HTinabox" with 7 little cube speakers and a 6inch subwoofer and it sounded simply awful and the real estate agent could not understand why I asked her to turn it off
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 26th December 2012, 01:35 AM   #116
Bigger=less movement for the same output = less distortion.
Old 26th December 2012, 03:29 AM   #117
so they say, but may not come that easy
many factors could influence distortion
and distortion at what frequency, SPL, etc
but I can tell you, this special 15" plays very clean bass on bass guitar
very advanced design
for hifi/music its probably only good when very loud
http://www.faitalpro.com/products/LF...p?id=201060150
Old 26th December 2012, 06:09 PM   #118
I thought that was exactly how you get around the effects of non-linear distortion.
Old 26th December 2012, 06:52 PM   #119
Originally Posted by blakkshepeaudio View Post
...Client has decided to go with the Eminence coaxs, either a 12" 2 way or a 10" plus sub...
I see I'm jumping in "late" (a LOT of posts in a short time!) but as a metalhead AND speaker engineer (including a bit of PA) I can give some unique perspective.
I think what makes a system "crankable" for metal in particular is the ability to play loud midrange without distortion. A lot of hard rock and metal have screaming guitars going on with screaming singers. There are a lot of frequencies overlapping and possibly intermodulating.
Maybe in smaller systems, like 6" 2-way home or car, the woofer is trying to move too much to replicate the bass, and this causes the midrange to poop out. Paul Klipsch was big on fighting this kind of distortion. OR, the woofer is being driven out of the linear range and the midrange is not reproducing linearly. AND probably some little 1" or smaller tweeter just cannot keep up...hence the use of horns for PA.
The first powerful speakers I built for myself had 15" woofers, E-V mid horn (2.5x14" or so) and T35? tweeter as used in the Klipschorn.
So you need BIG woofers. There is simply no substitute, whether they are in each cabinet, or you use a subwoofer (or maybe smaller woofers in a folded horn like Bill Fitzmaurice's stuff). Then you need some kind of mid/high that can keep up-usually a horn.
Past that, it is hard to comment more without more particulars about size and budget.
Eminence coaxes are probably a good choice. I might vote for 10" with the possibility to add a sub-maybe folded horn-in the future or now. This
Using coaxial products for DIY monitors and home hi-fi applications | Eminence Speaker
will interest you, as he refers to some good crossovers.
P.S. forget pillow stuffing. Fiberglass is better, and there are better materials than that. Get Vance Dickason's Loudspeaker Cookbook, he measures all kinds of materials. I've had good stuffing make a really shocking difference in the sound quality.
Old 26th December 2012, 07:16 PM   #120
Saying you need loud midrange and then saying this means big woofers
makes no sense for a 3-way. The Tarkus has a big mid unit. YMMV.
For the bass unit, excursion is just as important as size also.
rgds, sreten.
Heavy Metal berkshirejd Music 65 4th February 2011 06:55 PM
Heavy Metal distortion. Stormrider Instruments and Amps 7 7th February 2008 09:52 AM
So what's Your Heavy Metal name? pinkmouse The Lounge 18 20th June 2006 08:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
