New Use for Ferrofluid?
Old 20th December 2012, 12:42 AM   #1
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
Default New Use for Ferrofluid?
I just read an article in Popular Science about the speakers in Sony's BDV-N790W home cinema system.
"Designers replaced a key speaker component, the damper, with a microns-thin layer of ferrofluid.... The damper ensures that the spring [??] doesn't wobble and that the [driver] diaphragm doesn't overextend. But dampers cause friction, which creates sound-distorting vibrations and can lower a speaker's overall volume. Ferrofluid holds the coil and diaphragm in place, without friction. Without a damper in the way, the speaker can reproduce louder - up to three decibels - clearer sounds across all frequencies."
Sony claims that these speakers play louder and more clearly than any others their size. They probably still sound like cheap crappy home theater-in-a-box speakers, but would anybody care to dissect this?
Soft Dome
Old 20th December 2012, 01:00 AM   #2
ScottG is offline ScottG  United States
"Damper" = Spider..
It's been done several times before - most notably offerings from Ted Jordan.
perspective is everything
Old 20th December 2012, 01:37 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The JBL/HK 25mm "FR" (1st seen in the 2nd major rev of the iMac) & the 35mm version both had ferro-fluid spidders.
Mark Audio Alpair 5 (Jordan J6) is a good examle too...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th December 2012, 01:46 AM   #4
sdclc126's Avatar
So it's not an innovation for Sony, as the article implies. Not surprised.
Well, is it an "audiophile" improvement? It apparently is not very widespread.
Soft Dome
Old 20th December 2012, 02:02 AM   #5
frugal-phile(tm)
planet10's Avatar
I believe only useful for small drivers and tweeters.
On a small FR you can warm up the voice coil and expell some of the fluid/oil and they quickly deteriote from there.
dave
New Use for Ferrofluid?Hide this!Advertise here!
Ferrofluid Tweeter in a Lathe - Any Concerns? bmwman91 Multi-Way 10 27th May 2010 12:16 PM
Where to buy ferrofluid ? thylantyr Multi-Way 9 10th May 2005 08:42 AM
Do not understand ferrofluid. tade Everything Else 10 5th May 2005 02:27 AM
Ferrofluid and its Effect on Distortions? brummkreisel Multi-Way 3 24th July 2004 10:42 PM
Ferrofluid tweeter misshap! Tino Multi-Way 3 10th January 2004 07:27 PM
