How to obtain Punchy Bass ? - diyAudio
Old 19th December 2012, 09:04 PM   #1
batam is offline batam  France
Default How to obtain Punchy Bass ?
according to you, what would be the criteria for a speaker to render very "punchy" bass (not the extreme low frequencies, but more like 100Hz), something that really punches you at every impact ?
Something you can feel in your chest (like the percussions in Cherry Bomb or Hurt So Good from John Cougar Mellencamp).
The fact is, I am using B&W 684 right now cause I like their highs and mids (not tiring) and unfortunately, I feel like the lack of Impact.
They are installed in a rectangular 14m2 room(my desk), positioned on the shortest side and can hardly be moved.
So, I am wondering if I could find commercial or DIY speakers that will render that sound I like (my 12" Focal Utopia 33VX subwoofer doesn't give the impact, only very low frequency like it's good for home cinema).
Thanks for your replies.
Help me !
Old 19th December 2012, 09:47 PM   #2
chris661's Avatar
Punchy bass occurs at considerable volume - when its quiet, you won't feel it.
A 12" midbass per side would probably do what you're after - you could add a 12" midbass, cross to the B&Ws at, say, 300Hz, and gain considerable SPL capability in the ~100Hz region.
Chris
Old 19th December 2012, 10:30 PM   #3
Loren42 is offline Loren42  United States
A digital EQ.
Old 19th December 2012, 10:37 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
maybe you need better.... or different amps
Im certain those monster Krell amps in vendor's bazaar will cure that...but less will do
Old 19th December 2012, 10:41 PM   #5
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
High Qts woofers will give that 100Hz bump you want.
Old 19th December 2012, 10:44 PM   #6
and then he will soon be back asking how do i get rid of that....
Originally Posted by Loren42 View Post
A digital EQ.
basicly it 'could' be a room related problem, yes
room EQ ?
Old 19th December 2012, 10:52 PM   #7
sdclc126's Avatar
Cool I can't imagine anything other than
a flat, accurate and neutral reproduction throughout the frequency band, but that's just me.
Soft Dome
Old 19th December 2012, 10:54 PM   #8
now that I have checked the B&W 684 I can fully understand why they don't give you the chest punch
man, its a 2.5way with 6" woofers
they are not designed to play loud at all, sorry
you may have a chance with two subs crossed high about 100-120hz, and main speakers crossed with steep 24db 150hz highpass
my guess is the subs should be big 18" pro woofers, and not 'ordinary' subwoofer stuff
but please, don't crack up the house
Old 20th December 2012, 12:05 AM   #9
CLS is offline CLS  Taiwan
When a bass note hits hard to make you feel the impact, it'd be a wide band signal -- a transient response covering low to high frequencies, and all of them are excited simultaneously.
(If there's only bass, then you'd hear a soft and woolly sound, not 'punchy' at all.)
So, reasonably flat response with wide enough band and coherence are all important - to give you a fast rise of all frequencies at the same time.
Therefore, I have a feeling that a good single driver fullrange (small) system usually gives better punch than mulitway speakers in equivalent size, when playing within moderate SPL.
Playing loud, single driver speaker runs out of headroom earlier, then multiway takes the lead. You have to be careful in the xover and overall integration to get that coherence back.
Old 20th December 2012, 12:12 AM   #10
Moondog55's Avatar
Cross the Focal sub higher perhaps and listen to see if there is any difference in impact??
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
small punchy Karlson systems freddi Multi-Way 0 22nd April 2012 04:47 AM
low punchy bass simza03 Subwoofers 3 30th August 2009 11:03 AM
Recomnbed woofers/Mids for punchy yet deep bass? xenu Multi-Way 14 21st April 2009 02:32 AM
Punchy 813 Poweramp ak_47_boy Tubes / Valves 23 8th January 2007 11:08 PM
Worth upgrading cheap av with a punchy driver? VvvvvV Subwoofers 2 24th November 2005 01:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
