Can anyone reccomend a good place to pick up some bitumen damping material like the pads Troels uses in Europe? When I lived in the states I just ordered rolls of the stuff from Parts Express but in Austria I am having a hard time locating the stuff, Thanks in advance!
#2 |
I got Monacor MDM-830 Bitumin pads from this place:
CarPower MDM-830 Non Drown Foil You'll need to check about Europe delivery. These pads are nice and thick. |
#3 |
Sound proofing and dampeneing plates for metal panels in cars etc. used to be loaded bitumen..... car supply houses still sell damping plates :-)
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#5 |
I'm a great fan of just using some common builders material. Regupol K225 is a heavy mixture of rubber tyre granules and cork used as 4mm acoustic insulation under wooden floors. Seems to do the job and accords with my view of what the stuff does in damping!
Surprisingly you apply it most thickly to the smaller panels in BBC style with spray-on carpet adhesive. Then add foam or stuffing to taste. FWIW, IKEA do little stick-on kitchen cabinet door dampers which double as isolating speaker mounts too. Cheap as chips.
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK. |
#6 |
Try Dynamat Extreme. I use it for amplifier cases or speaker chassis. Dynamat DYN10425 Xtreme Wedge Pack: Amazon.co.uk: Car & Motorbike
For speaker cabs I stick stone chipped roofing felt with bitumen emulsion.
#7 |
It's never too late to have an happy childhood http://www.homebuilthifi.com/project/5604 |
#8 |
Wilmslow Audio used to sell them .
#9 | |
| Where to buy CS8412 in Europe | Sabas | Digital Source | 4 | 27th July 2005 01:34 PM |
| where to buy cs8414 in europe | sunrise | Digital Source | 3 | 24th May 2005 04:23 PM |
| Fountek Ribbons Group Buy (Europe, but maybe not only Europe?) | Carondimonio | Group Buys | 34 | 24th October 2004 08:10 PM |
| Where Can I Buy Cz8414/tda1543 In Europe | PTSOUNDLAB | Digital Source | 19 | 1st September 2003 07:10 AM |
