Stargate
Stargate
Old 19th December 2012, 03:59 AM   #11
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Here's some more pictures of stargate
Overhead view of the device
The very wide vertical dispersion is due to the VERY narrow vertical mouth. Just one half of a centimeter. The big black plastic roundover is there to reduce diffraction at the mouth. The reason that it's only rounded on one side is that it's designed to be placed in a car, where the dash extends the curve on one side, but not the other.
This is the on-axis response of the device
My measurement technique isn't terribly sophisticated; this was measured using the RTA on my iPad, on axis, at approximately 2 feet. Levels are fairly low as I didn't want to blow up the compression drivers. (There's no xover in the mix.)
This is the same measurement, at 45 degrees off axis. Note how similar it is to the on-axis response. (Ideally we'd want the exact same shape, but at a reduced output level.)
The two graphs overlayed.
Not too shabby huh?
Old 27th December 2012, 06:14 PM   #12
SEdwards is offline SEdwards
How is it sounding?
Old 28th February 2013, 12:39 AM   #13
Turned out really well actually! It's amazing how directional it is, and how smooth the response is, considering the reflectors.
Old 28th February 2013, 12:45 AM   #14
454Casull is offline 454Casull  Canada
Originally Posted by planet10 View Post
We know, we know... nothing less than a 15" Tannoy can possibly do the job.
dave
What's so good about 15" Tannoys anyway?
Old 28th February 2013, 06:53 PM   #15
Don Hills is offline Don Hills  New Zealand
Size matters.
StargateHide this!Advertise here!
New Reference - SG-OB "Stargate Open Baffle" Magnetar Multi-Way 67 17th July 2008 07:04 AM
Nearfield Stargate Magnetar Multi-Way 18 27th July 2005 02:38 PM
