Anyone tried an Eminence Beta 15a in an H Frame? - diyAudio
Old 15th December 2012, 04:21 PM   #1
mortron is offline mortron  Canada
Default Anyone tried an Eminence Beta 15a in an H Frame?
Just considering woofer choices for my OB project. I have seen my fair share of Alpha 15 H frames but no Beta 15 H frames. I know the Alpha is preferred for the high Qts, but have heard comments on the Beta as going a bit lower and sounding a bit more defined with eQ (I've pieced together a few comments there ). The magnet size I'm sure has some influence. Using eq to boost Q, is it logical to think we can get similar performance to an Alpha from a Beta 15? Has anyone tried this? Assuming one can get it to do so, I agree with another's logic that to cheap out over $10 or so dollars may not be worth it if the SQ is better.
I am torn between the Beta, Alpha and Goldwood 1858 in an H Frame (possibly for fun, ive considered a slot load the Beta ala Pass Burning Amp 2012).
Old 15th December 2012, 04:47 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
actually, a few members have 'recommended' to use the Beta instead
evenso, somehow the Alpha still seems to 'stick'
as does the Eminence for OB, in general
but also Fane could have a good 'contender' among the Sovereign woofers
Old 15th December 2012, 05:07 PM   #3
With eq the Beta's will be fine. Personal preferences prevail when it comes to high-med-low q drivers for dipole bass. Try both
I use the Eminence Delta 15 LFAs in u-frames, and with eq I'm quite happy with the bass. I've used high Q drivers in the past and I prefer the Deltas. I have to use about 14db of boost on the low end, and I shelf from 100hz up -8 to get flat response down to 40hz.
How loud and how low do you plan to run these? Excursion can be an issue with the kind of eq you're going to need and high spl.
Old 15th December 2012, 05:49 PM   #4
I have a 15x12x9 lwh room. I listen to everything from jazz to metal.
I am more interested getting a woofer that is defined than a few extra Hz... a dozen extra Hz, I can be persuaded
Likely, a single driver h frame per side is my best option in my current rented location.
Old 15th December 2012, 06:13 PM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
A picture is IMO needed:
Note: To equate the Beta driver FR-wise in a H-Frame a ~6,8 Ohm driver must be added to achieve a similar response.
b
File Type: jpg Eminence_Alpha-Beta_15inch_H-Frame.JPG (307.8 KB, 500 views)
Old 15th December 2012, 07:04 PM   #6
What is the ~6,8 ohm driver? A 6.8 ohm resistor? I'm confused.
Old 15th December 2012, 07:13 PM   #7
or could be a matter of a little bass, or no bass at all, more than just a few hz
anyway, defined bass will have close relation to crossover phase with other drivers in your speaker
Old 15th December 2012, 08:00 PM   #8
If you add a 6.8Ohm power resistor in series with the Beta Driver then the Qts= 0.585 moves up to Qts= 1.126 but at an expense of a large power loss as a undesired consequence...
b
Old 15th December 2012, 08:04 PM   #9
chris661's Avatar
I've heard Beta 15s on an OB (flat baffle) - there's sufficient bass, but IMHO sounds better than I've heard an Alpha 15 (which has a tiny motor trying to drive a huge cone).
Chris
Old 15th December 2012, 08:31 PM   #10
b
So added resistance increases the load to ~14.8ohm? Me just needs more power? Will the woofer suffer any other shortcomings?
How does changing the dimensions from the 16x16" cavity to say 20x20" change sound and response??
Tang Band W8-1808 / TB ribbon tweeter / Eminence Alpha 15A in OB with U-frame superlian Full Range 3 4th September 2011 12:11 AM
FS: pair Eminence Omega Pro 15A woofers & pair Eminence PSD 2002 8 nicksgem10s Swap Meet 0 30th June 2011 01:37 PM
Crossover for Eminence 15a on H Frame Doc Jr 8156 Multi-Way 1 3rd November 2010 10:32 PM
Designs which utilise Eminence Beta 15A? wixy Multi-Way 9 13th June 2009 06:04 PM
Copyright 1999-2017 diyAudio
