audax pr170mo
audax pr170mo
Old 15th December 2012, 11:12 PM   #11
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
audax pr170mo
Personally, I wouldn't take them below about 250/300Hz at the bottom, (unless you listen at very low levels), they are quite fragile, but worse, don't actually sound that nice at the low end. Non horn loaded, I'd run them up to about 4-5K at the top.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 15th December 2012, 11:46 PM   #12
murphythecat8 is offline murphythecat8  Canada
yeah that was my plan. 300hz and 5khz...
Old 15th December 2012, 11:47 PM   #13
POOH is offline POOH  United States
POOH's Avatar
Originally Posted by murphythecat8 View Post
okay, and what is their limit in your opinion? where to put the crossover?
I will be doing the pro-38 enclosure for the audax which is a irregular enclosure...
Depends on a lot of factors, what woofer and treble. Using 4th order electronic crossover with no passive contour they sound best 400 to 2k (actually going into breakup at around 2.3K if I remember correctly) but you can stretch that quite a bit on top because they're good) . I've used them with a first order passive crossover over at 4k to a ASG1 99 db sensitive ribbon and it was a lot of fun. Another good match (much less $) is the little Eminence APT80 tweeter.
Old 16th December 2012, 12:29 AM   #14
ill be using the audax pr120 for the supertweeter and the beyma 12br70 for the bass.
I plan on first order at 300hz, I really want the lower possible because im going active with my beyma and want the tone to match so dont want the beyma to go in the midrange ideally.
anyways, will report soon!
Old 17th February 2015, 09:54 PM   #15
Kwikas is offline Kwikas  Australia
Originally Posted by POOH View Post
The driver is good as a direct radiator yet even better in a large mid horn. It's upper range in a horn is 1.5k so it makes it easy to mate with a good 1" compression driver. The horn loading gives it more headroom then direct radiator but the pr170mo still lacks the dynamics I get with some other horn loaded cones so I do not use them except in rear ambiance channels.
Is there a mid range horn available off the shelf or does one have to design it (Hornresp)?
......and yes I know the thread is 2 years old but I have a couple of these drivers and I want to horn mount them.
Old 18th February 2015, 01:29 AM   #16
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Heard them on OB years ago with ported Altec VOT woofers and Klipsch horn tweeters in a DIY setup. They were excellent!
Old 18th February 2015, 09:34 AM   #17
They certainly are a nice driver Godzilla. I just can't seem to find any horn designs for them.
I have two mid range horn guides out of the JBL PRX535 which took JBL 195H drivers (Eminence LA6-CBMR) and I was hoping my Audax PR170mo's (same as JBL 165H) would fit them but the Audax's are slightly too large...
Old 25th April 2016, 03:02 PM   #18
SpeakersinBelgium is offline SpeakersinBelgium  Belgium
Default Audax - PR170MO
The Audax is not intended as a drijver for a large horn. Just use them in a closed enclosure (about 10liter) and they will work fine from 400Hz to about 3000-3500Hz, with very low distortion and sound pressure of 100db/2.83V at 1m distance. I measured them in 10liter CL-box and can confirm better than +/- 2.5db linearity...
I use original Audax units from 20years ago - I don't know about the quality of todays factory. I think these chassis were a long time ago discontinued. I even do not know about the original Audax company. Only a very few chassis can be bought today - somebody my have restarted production from the old (but very good!) designs...
Currently using 10inch Beyma with PR170MO and CP25 Beyma tweeter in 3way design... (plus a subbass horn below 80Hz)
Old 25th April 2016, 04:02 PM   #19
Charles Darwin is online now Charles Darwin  United Kingdom
I think Audax went bust but was later partially resurrected originally to build spares for existing speakers.
As far as I know there no plans for new designs. Shame really as I for one would like to see a modern high excursion, low distortion midwoof with an aerogel cone.
The current models sound very good but are a bit limited excursion wise.
Old 25th April 2016, 06:23 PM   #20
Default PR170MO
Hi Charles and others...
What I want to say is, that my excellent measurement results I got from old new stock (I bought the chassis about 20-25years ago from Audax) and opened one old box recently to use the speakers finally.
Excellent results!
But I notice that there are several webpages actually, who offer PR170MO units new! As Audax originally are not in business anymore, I personally wonder where this sales stock comes from and if the newly produced units have the same quality as 20years ago from original Audax factory.
regards,
audax pr170moHide this!Advertise here!
Audax PR170MO... chrismercurio Multi-Way 55 14th June 2017 07:49 PM
Wtb: Pr170mo mitchyz250f Swap Meet 0 25th September 2009 01:09 AM
Audax PR170MO Brett Swap Meet 0 14th August 2004 02:41 AM
Woofer Suggestions For PR170MO? delwon Multi-Way 4 31st December 2003 10:59 PM
Looking For PR170MO Suggestions delwon Multi-Way 1 8th December 2003 06:44 PM
Copyright ©1999-2017 diyAudio
