swapping woofers with 2db difference in sensitivity - diyAudio
Old 14th December 2012, 10:29 AM   #1
Default swapping woofers with 2db difference in sensitivity
Planning to swap a focal 11w to 11wx without crossover changes.
Both are 11" and the 11wx is 2db lower in sensitivity. I assume since the drivers are both focal, tonality should not be far off.
Will this be a mistake as and have low bass output from the new driver?
Old 14th December 2012, 12:18 PM   #2
2dB is quite a lot! i would recommend pulling down the level of the other bands.
__________________________
kickin the place all over the bass
Old 14th December 2012, 02:12 PM   #3
'Both Focal' is like comparing a Volkwagen Beetle to a Golf. Same brand, similar size, but different car nonetheless. The type numbers may sound alike, but they're different drivers. It's well worth the effort to find the correct types if your original drivers are defective!
Old 14th December 2012, 03:03 PM   #4
mondogenerator's Avatar
agree. 2db is certainly audible, and similar model numbers doesnt necessarily make their sound similar.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 14th December 2012, 03:09 PM   #5
The sensitivity difference is actually pretty negligible in the main 100-1000Hz range, but a look at the spec sheets shows that everything else is pretty different. The impedance curves alone rule out using the same crossover, assuming you are starting with a crossover designed for the first driver. UNLESS, I found the wrong spec sheets...
Old 14th December 2012, 03:36 PM   #6
The focal11wx is much better unit than the 11w inmy focals.with age, the spiders are lstarting to cause problems with low bass material and felt it may be a worthwhile stab in the dark.
I maybe adventurous to swap resistors of the tweeter and mid in the even the bass output is insufficient.
Given room acoustic issues with any set of speakers with muddy and boomy bass, swapping a superior driver may morethan compensate of a unoptimised cross over?
Do my thoughts hold and room to experiment?
Old 15th December 2012, 07:34 AM   #7
The only way to be sure is to try it!
Old 15th December 2012, 03:11 PM   #8
puppet is offline puppet  United States
My guess is that if you're going to experience a change in sensitivity lower is better than higher. Depends on where they're xo is too. Personally, I can hear a 1/2db change in typical woofer range.
Old 15th December 2012, 05:52 PM   #9
AJ34 is offline AJ34  United Kingdom
[QUOTE=justubes;3284645]Given room acoustic issues with any set of speakers with muddy and boomy bass, swapping a superior driver may morethan compensate of a unoptimised cross over?QUOTE]
Not necessarily.
I don't think anyone can say for certain (unless they've actually tried exactly the same modification) how well such a change would work out but chances of success are stacked against you for reasons already mentioned. No harm in trying but have a 'plan B' in mind.
There may still be a few specialists out there that will design you a completely new crossover for your intended drivers - as Wilmslow Audio (UK) did when I replaced both SEAS drivers in a two-way passive system with two Focal drivers. Worked a treat. Good luck.
Old 16th December 2012, 06:23 AM   #10
I don't have the specs for the tweeter and mids, but do have the existing crossover diagram.
Neither do I know the existing spec for the woofer to be replaced.
This option may be tough.
I was just think to use a l-ad for the miss and tweets in the worst case senario.
[QUOTE=AJ34;3286235]
Not necessarily.
Swapping potentiometer ArthurZ Analog Line Level 3 29th October 2012 06:49 PM
best high sensitivity woofers? Bill poster Multi-Way 15 30th March 2010 08:48 AM
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 07:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Swapping an A/C Adapter FrankRoss Power Supplies 2 11th May 2006 01:16 AM
Copyright 1999-2017 diyAudio
