8/10" worthy of ATC SUPER MID? - diyAudio
Old 11th December 2012, 05:45 PM   #1
Default 8/10" worthy of ATC SUPER MID?
Hi guys
I am building a big monitor(WMTMW) with dual ATC 75/150S $ SS-7100 tweeter.I would like to cross at around 400hz/3500hz-24dbLR.
So I am looking for some 8's or 10's of good quality to keep up and hopefully keep the soundstaging up.I was looking at the 10" Volt but it is only 92db and I will need at least 95db.
I was wondering if anyone has found some good drivers to fit?
thanks john
thanks John
Old 11th December 2012, 06:20 PM   #2
Volt BM2500.5
I assume you were looking at the BM2500.4. Compared to that you will lose 10 Hertz of bass extension but you do gain 3dB in efficiency.
Can't think of anything that comes close to either of these two.
That said personally I would not use the ATC mid in a WMTMW configuration since their magnet size does not allow them to be mounted close enough to each other or the tweeter.
Old 11th December 2012, 06:39 PM   #3
I have looked at it and being that I am using the Aura NS-18 for all the lows,this may work.
As far as a MTM,if one makes a plate and remove the tweeter plate,but use the small inner screws for the new plate,you will gain another 1.5cm closer for the mids.You donnot think this is enough?
thanks John
Old 11th December 2012, 07:05 PM   #4
As far as I understand the centre-to-centre spacing of the mids should be 1/4 the wavelength of the crossover frequency. At 3500Hz that would be 2.5cm or one inch.
I don't think you'll get two ATCs close enough for even half wavelength as they are huge.
Their magnets are about 15cm in diameter.
Why are you so hung up on the 10" efficiency? The woofers you use only do 86dB/1W. How about a Volt 18"?
Old 11th December 2012, 07:06 PM   #5
diyAudio Member RIP
Doubling up the ATC dome midrange is a very poor and expensive design choice.
Its simply not needed in any sensible speaker design, and ATC don't do it.
Zaph|Audio, see Sept 2011.
Accounting for some baffle step one driver matches up with a 93 to 94
dB/2.83V bass end, and that is plenty enough to be getting on with.
rgds, sreten.
4th order L/R acoustic mid to treble would be good, driver spacing
means the lower the frequency the better, but trade that off
against the power handling of the tweeter.
4th order L/R acoustic bass to mid will be complicated by baffle
step, and 2nd order L/R acoustic might work better, and YMMV.
Old 11th December 2012, 07:58 PM   #6
the mids will actually be stepped back around 25mm from midbass on the baffle.
thanks John
Old 12th December 2012, 10:12 PM   #7
The problem is not crossing over from the midbass.
The thing is that you won't be able to get the ATCs close enough together with a tweeter in between NOT to cause any problems.
Old 13th December 2012, 07:59 AM   #8
I often wondered about a slight offset of the tweeter.
thanks John
Old 13th December 2012, 01:28 PM   #9
You could offset the tweeter a wee bit but you still won't be able to the ATCs close enough together to avoid problems.
In an MTM design the center-to-center spacing determines the highest frequency at which you can cross to the tweeter.
Let's say you have the ATC but up against each other, the minimum center-to-center spacing would be roughly about 0.16m (16cm) or 2100Hz wavelength.
The sub-optimal half wavelength would mean you'd have to cross over to the tweeter at 1050Hz. You really want to spend the cash for two ATCs when you can only use 1/4 of their range?
MTM works fine but it really requires two small cone mids crossed low to a large diameter (or at least low frequency capable) tweeter.
And yes I think most commercially available MTM designs are flawed in that respect ie the mids are too far apart mostly.
If you had your eye on an MTM design due to its point-sourciness (and I don't blame you, I've got Tannoys for the same reason) think about it this way: A single ATC mid covers such an important and large part of the spectrum that you are already 90% there with just one of them.
Old 13th December 2012, 01:49 PM   #10
Telstar is offline Telstar  Italy
This is true and the reason the ATC dome mid is not used in MTM is just cost.
Now about the lower mid recommendation, I second Volt, but there are quite a few capable midbass, although less efficient. None beats the Volts in linearity though
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
10" woofer/mid-range for 2-way build Rullknufs Multi-Way 56 4th November 2013 01:30 PM
JVC AX-2 Integrated "Super A", Marantz Circa 1978, Realistic 10 band EQ enigmaticEntity. Solid State 1 21st April 2012 07:20 AM
BK202 and AN Super 10" CF whrnet Full Range 0 4th October 2009 07:59 PM
High Efficiency 10" Mid Suggestions Impious Multi-Way 13 10th March 2009 09:21 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
Copyright 1999-2017 diyAudio
