Larry Wormer's LX5 Crossover Help - diyAudio
Old 11th December 2012, 04:18 PM   #1
Default Larry Wormer's LX5 Crossover Help
I am looking for some help understanding the crossover the Larry Wormer built for his Optimus LX5 speakers.
See the article here: LX5
First, Larry describes his crossover as a sixth order, but the diagram shows only a third order. Is it possible he used some advanced theory to simplify the crossover to use only 3 components? My own research shows this to be impossible. A sixth order crossover needs 6 components to work.
If he misspoke and did create a normal third order crossover, how come I can't reproduce his values? On my LX5s, the tweeter has a Re of 6.2 and the woofer has a Re of 4.7. This means a third order filter on the tweeter would be a C1 of 8.8, an L1 of .3 and a C2 of 26. Larry's C1 is 7.2 and his C2 is 10. I can't figure out how he got those values. A Re of of 7 on the tweeter would give me a C1 of 7.5 (close enough), but C2 is 22 (nowhere near 10).
Any thoughts?
Old 11th December 2012, 04:34 PM   #2
picowallspeaker's Avatar
by taking advantage of the driver rolloffs
That's the point: probably the software (Calsod) has to hit the target when referring to the final curve/slope/roll-off. So a woofer (and also a tweeter)
has a natural 2nd order rollof, accentuated by the box/baffle .Just sum
the gradients/slopes and you have the desired 6th order. One thing is the electrical roll-off, but the target is acoustical .
Old 11th December 2012, 05:13 PM   #3
Thanks for the reply Pico,
I see now what he meant by sixth order, but electrically only three....I guess it was just the way he wrote it didn't work for me.
I plan on getting a hi-vi Kevlar woofer to go with my linaeum tweeter, and will be making my own crossover + box and wanted to know how he got his crossover values so I could make the same improvements to my own.
Guess I was hoping there was new advanced theory I could check out, but in reality, it was probably all in that software. I like to double check things and learn how to do the work myself, but I can't do that without knowing how that software works.
Off hand, do you, or anyone else, have some suggestions I can research for incorporating a natural roll-off into my crossovers?
A quick search online showed something about a transient perfect crossover? Is that the actual term for what I am looking for?
Old 11th December 2012, 08:07 PM   #4
Oh..well..er : you're welcome
I'm not into simulation and measurement at all, I just swap
things that are in the basket.
About perfect transient response, that might be theoretically true
just for the tweeters, and among them only isodynamic/ribbon tweeters
might perform fairly well regarding that particular parameter.
Like for crossover analysis, there is the electrical part and then there
is the electro/mechanical/thermic/??? that is the loudspeaker, which has
some mass so it's impossible to make it start&stop suddendly.
Not to mention the whole system, which is subjected to many filterings
(like the Cd anti-aliasing low-pass at 20 KHz ) that have the effect to limit
somehow the transient response.
Old 11th December 2012, 09:59 PM   #5
Kinda sounds like I shouldn't bother
I was hoping that since these linaeum tweeters were ribbons, I would try some different crossover topologies and perhaps run them real low.
I am still going to try some different things of course, I was just trying to understand what Larry was doing with his.
I don't think matching the roll-offs is going to be what I want anyways. According to Madisound, the Hi-Vi L5-8R starts rolling off after 6KHz....I didn't want to run it that high. I was hoping to run the tweeter real low so I get as much of the ribbon sound that I can get. As far as I can tell, no one has actually tried going real low with this tweeter.....
The Dayton Audio DATS system won't measure it so I have nothing to go on besides guess work.
Old 11th December 2012, 10:32 PM   #6
diyAudio Member RIP
You can't run the ribbons real low, end of story.
Your best bet is to follow the mods. Don't introduce
a driver you don't have a good known x/o design for.
rgds, sreten.
Ex owner and modder of LX5's.
Old 13th December 2012, 07:30 PM   #7
Well, I am going to follow the mods as described and see what happens. I am still suspicious of them since I can't recreate any of the values he chose myself. Even the imped comp doesn't match up with anything I have figured out myself, both measure values and listed values I found online.
Odd.
Thanks for the replies everyone!
Old 13th December 2012, 07:40 PM   #8
diyAudio Member RIP
Nothing odd about it. Online calculators are crap.
Make sure you have the version the mod is for.
The sixth order acoustic x/o uses lower order
electrical slopes along with the drivers responses.
The drivers must be the same for it to work well.
rgds, sreten.
Better woofers for Optimus Lineam LX5? dpuopolo Multi-Way 5 5th May 2015 05:29 PM
Larry Moore power supply korneluk Tubes / Valves 0 24th December 2008 04:23 PM
Larry Moore 10Y Squared korneluk Tubes / Valves 5 25th June 2008 05:40 PM
OT: Ping Larry L. hooha Subwoofers 0 7th April 2007 12:11 AM
Copyright ©1999-2017 diyAudio
