diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Help with Avance dana 660 center crossower (http://www.diyaudio.com/forums/multi-way/225322-help-avance-dana-660-center-crossower.html)
MartinAndersen 9th December 2012 03:43 PM
I am in deep trouble :(
I bought the dana 660 center speaker and the sound was OK, but of course I had to look at the filter I decided to build a new one with better components but something was lost in translation.
The diagram in the link above shows a drawing from the PCB board from the original filter, but I must has missed something because the speaker sounds like sh.. now.
I can here you say, look at the pcb board again right!! but I throw it away :wchair:
Can anyone help do a review of the diagram.
Link to filter diagram
PeteMcK 10th December 2012 02:34 AM
can't see that pic, can you add it as an attachment here?
MartinAndersen 10th December 2012 06:49 AM
You can't open the link? it's working in Chrome (-:
1 Attachment(s)
I have attached a picture of the filter
xjr100 11th December 2012 07:50 PM
Originally Posted by MartinAndersen (http://www.diyaudio.com/forums/showthread.php?p=3278400#post3278400)
Suspect that 1.5uF which is in parallel with resistor are in wrong place.
It is typical values foe zobel, put them 1.5uf+R (sequentally) in parallel to tweerer.
Copyright 1999-2017 diyAudio
