2way vs 3way, same sound?
Old 7th December 2012, 06:37 PM   #11
Pano is online now Pano  United States
Pano's Avatar
I basically agree with all of the above. A 3 way has the potential of sounding better, but you had better be good at crossover work. A 6.5" driver is already a mid to some of us so getting it to play up to a 1" tweeter should not be too hard.
Take the Speaker Voltage Test!
Old 7th December 2012, 08:41 PM   #12
timlub is offline timlub
There is no way to say that a 2 way or 3 way in general sounds better than the other, driver matching, box design, even the mid enclosure, crossover points and slopes all matter, but a 3 way allows to keep the crossover out of the vocal range, but if time alignment, phasing in the crossover and frequency peaks and dips are dealt with, either is excellent and they can sound equal if attention to detail is given, but never sound exactly the same.
Old 7th December 2012, 08:53 PM   #13
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
It comes down to execution. Driver choice is a big factor. We are always working within a budget. 2 drivers + 1 XO point, vrs 3 drivers + 2 XO points.
For me a 2-way has an XO between 150-400 Hz, 3 way adds an XO point at 50-60 Hz (i feel it is important that C-C is not greater (or much greater) than a 1/4 wl at the XO point).
If you follow the work of Toole & Geddes, mains should reach to ~80 hz, below that you use multiple separate woofers pkaced to give smooth in-room response.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th December 2012, 04:05 AM   #14
I don't post here often, so sorry, I don't know everyone, but I understood the op to be crossing a 1 in dome to a 6 1/2 compared to a 3 way.
Quote: "a 2-way has an XO between 150-400 Hz, 3 way adds an XO point at 50-60 Hz"
I would take that statement quoted as working with pro parts or a full range adding a very low frequency driver below the full range, but I do agree that Execution is everything.
Old 8th December 2012, 07:21 AM   #15
head_unit is offline head_unit  United States
Originally Posted by leadcoma View Post
But if I can get the on-axis in-room frequency response at the listening position to be the same, is the sound any different?
Yes. Because what you are talking about is just the magnitude in decibels of the sound. You are completely missing the TIME response.
Example: speaker A has an on-axis dip -3dB at 2 kHz, but off-axis output is very high. Measures 0 dB at the listening position.
Example: speaker B is flat on-axis at 2 kHz, but off-axis output is none.
The two speakers measure the same at the listening position, but the ratio of direct to reflected sound will be quite different as will the time arrival and smearing of said sound.
As for 2-way versus 3-way, if done very well, the 3 way *could* offer a nicer midrange, by having a driver dedicated to that and taking some load off the woofer and tweeter. But it has to be executed very well.
Old 8th December 2012, 08:20 AM   #16
frugal-phile(tm)
planet10's Avatar
Cone & dome is the typical way of doing it. It puts an XO right where the ear is most sensitive. Pushing the XO way down moves the XO to where the evils it brings can be diminished.
dave
Old 8th December 2012, 10:24 AM   #17
a.wayne is offline a.wayne  United States
Sin Bin
Are you saying to xover to the tweeter at 150-200hz for a two way Dave ...?
Old 8th December 2012, 11:05 AM   #18
frugal-phile(tm)
planet10's Avatar
The "tweeter" i use on the pictured speakers goes down to 100 Hz. XO at ~350 Hz. Bass extension into the mid 30s or lower.
1st order XO with drivers within <1/4 wl at XO so are essentially co-incident. 1st order XO. So they have no lobing, and are phase coherent.
dave
Old 8th December 2012, 02:36 PM   #19
Barleywater is offline Barleywater  United States
Have you measured IMD performance of tweeter in this speaker setup? Multi tone including 300Hz component?
Crossover point selection based on human vocal range rather than driver performance is recurring theme, and is poor design compromise.
Tweeter claiming performance down to <300Hz is classifiable as full range, and will be replete with IMD and break up issues.
Andrew
Old 8th December 2012, 03:44 PM   #20
dewardh is offline dewardh  United States
. . .For me a 2-way has an XO between 150-400 Hz,
+1 . . .
Which I took to be dave's "tongue-in-cheek" point . . . there are a number of surprisingly (as in WTF??? surprising) good sounding and cheap 3-4" "full range" (not really, but that's what they call them) drivers which, for a given (low) price point, will outperform the "traditional" cone-pushed-too-high-to-dome-pushed-too-low introductory 2-way when combined with any of a number of inexpensive "woofers".
Typically what one "gives up" is "quality" in the range from 10 to 20 kHz. . . . but that has to be the most overpriced and under-delivering frequency band in all of audio . . .
2way vs 3way, same sound?Hide this!Advertise here!
What is the Best 2way speaker msj965 Multi-Way 32 5th June 2010 09:02 PM
linkwitz-riley 3way and 2way pcb kit?? aaronboumans Analog Line Level 10 13th April 2010 03:33 AM
SEAS 2way tpsorin Multi-Way 29 28th July 2007 09:50 AM
10liter... 2way... help... gcm908 Multi-Way 6 15th November 2004 05:35 AM
Seas 2Way. Baronty Multi-Way 10 20th October 2004 08:24 AM
Copyright ©1999-2017 diyAudio
