#41 | |
I site Klippel in this instance as one of many including myself that have performed multi tone testing, listening with both ears and microphone. All distortion is bad in reproduction. IMD is really bad, and operating a driver at wavelengths orders of magnitudes greater than driver's diameter is a great way to promote this. I can provide plenty of pictures, references and details, but experiencing these evils isolated first hand is only effective way to learn what they sound like, and leads to better identification of them in program material. Dave's apparent target with these speakers is phase coherence/lack of vertical lobing, and compromises with reduced linearity and power handling. Real performance metrics are only way to communicate this. I can't measure Dave's speaker performance, and I can't hear them, but real practiced knowledge leads to inference that as described, they have high levels of IMD from below crossover point to about 2kHz. Dave is welcome to flesh this out with real measurements. Regards, Andrew Regards, Andrew |
#42 |
I certainly agree that IMD is "really bad" (if there's enough to hear it), but . . . common nominal 3"-4" drivers have cones from 2.5" to 3" diameter, so they are less than an order of magnitude smaller than wavelength down to 500Hz. or below, and excursion will be a modest 1-1.5mm for 105dB . . . is that OK by you ? ? ? I'm just not seeing the IMD contribution as being greater than, or worse than, the cone breakup induced distortion and the radiation pattern problems of the larger drivers commonly used up to and above that frequency . . .
#43 | ||||||||
frugal-phile(tm)
The truth is that a mictophone is a tool. A very useful tool. It does not, though, "perceive" anything like the ear/brain. I have seen far too many people measure, look at the output and then "hear" what they saw.
and compression driver systems with distortion >6% covering the rest. Quote:
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#44 | ||
frugal-phile(tm)
Just as i have, till now, declined to comment on the measurements that Andrew has posted of his speaker, which has me wishing to hear if it has the qualities i fear it has from my interpretation (or misintrepetation) of the pictures/graphs. dave
#45 |
Says it all. Simply listening to the pass off from Oboe to Clarinet in the third movement of the Gran Partita tells me more about a speaker's midrange behavior than all the charts and distortion sweeps. The measurements certainly help in figuring out what's happening when it's "wrong", but they're still not enough to tell me it's going to be "right".
#46 | |
#47 |
A 3way is a 2way with subwoofer.
If you do it right you shout end up with better sub-bas and cleaner midrange with the 3 way. Because the mid-driver has to work less hard, and the woofer can be the right size. cross it low for less interference problems and constant directivity.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 9th December 2012 at 07:23 PM. |
#48 |
I would say much of it depends on how loud you play
best mid is a 4-5" type crossing low, it might be better to use a 6" if you play loud, I would think twice about crossing the mid bery low that said, a small 2way with a 5" can at times sound surpricingly good I have long wanted to try a 2.5way with 5" woofers but it easily gets expencives maybe some day when I get tired of big speaker subwoofer ? yeah, that too, but also expencive and my next speakers are probably bigger than any I have ever had
#49 |
frugal-phile(tm)
Lots & lots.
dave
#50 |
frugal-phile(tm)
THis is something that has becoming much clearer with the advent of acceptance od the subwoofer as a separate entity.
Toole & Geddes have really rammed that home. dave
| What is the Best 2way speaker | msj965 | Multi-Way | 32 | 5th June 2010 08:02 PM |
| linkwitz-riley 3way and 2way pcb kit?? | aaronboumans | Analog Line Level | 10 | 13th April 2010 02:33 AM |
| SEAS 2way | tpsorin | Multi-Way | 29 | 28th July 2007 08:50 AM |
| 10liter... 2way... help... | gcm908 | Multi-Way | 6 | 15th November 2004 04:35 AM |
| Seas 2Way. | Baronty | Multi-Way | 10 | 20th October 2004 07:24 AM |
