First impressions of the LX521 pretty much always include some comment about the baffle . . . usually its aesthetics. SL says that the shape was arrived at empirically, but clearly there is some “thinking” which justifies the departure from the more “normal” straight sides with steps, and many “empirical” solutions can be incrementally improved if there is a theoretical understanding of them, and why they work. That it does work (in the context of what a dipole baffle is supposed to do) I can attest from listening to it . . . the dipole null is pronounced and broadband, and extends vertically to the extent that I could determine, at least 45 degrees above the horizontal. The c-to-c spacing of the combined mids should lead to some dipole-like vertical beaming around the crossover frequency, and the undercut below the lower mid may extend vertical dipole behavior as well. But is it “optimum”? Is it possible to do better?
I intend to start with the basic LX521 baffle shape for my “clone” experiments (without the extension for the rear tweeter, which to my thinking could go anywhere), but I’m altogether open to suggestions for “improvements”. Any ideas ? ? ? |
#2 |
Years ago I thought about making a 4-way variation on Orion by adding a small upper midrange, and I always thought that would suggest bumping the 22cm midwoofer to a 26cm. The new LX521 baffle leaves the midbass driver pretty close to nude and its output will be limited toward the bottom if its range. A hybrid of Orion / LX521 / NaO Note II would have an Excel W26 midbass and Discovery 10F midrange. This would require a steep low-pass on the W26 which you could do with MiniDSP.
#3 | |
In fact, I would just use that for the top and forget about the dome tweeters! I would put an acoustic reflector lens on the rear of the vifa to diffuse rear HF.
I LIKE YOU
#4 |
I have compared 2 variants of the LX521 lower baffle shape (eg. without tweeter part) to a rectangular baffle. The rectangular baffle is 256mm wide, the LX521 variants at the widest point 315 and 331mm. The measurements I made are a bit messy but if there is any interest it could upload them somewhere. Regards |
#5 | |
The lower part of the midrange baffle has to work up to 1 kHz. That's a wavelength of 34 cm. I don't see how the specific shape of the baffle in that region would make a real acoustical difference compared to vertical sides. Of cause it does have some aesthetical and marketing advantages over the rectangular baffle. ![]() The part around the tweeters isn't of too much acoustical concern either - regarding the crossover at 7 kHz. The tweeters already start to beam, which will control the radiation pattern increasingly more than the dipole null. If you would cut off the "excess" baffle around the tweeters (as indicated in the picture), I don't expect a tremendous difference - but would surely be interested whether I can be proofed wrong. Now if you look at the "corrected" (red) baffle shape in my picture, it should strongly remind you of some other dipole 4-way speaker. I can't help but find the LX521 baffle as it is now more of a "statement". Its shape isn't dull, it calls for discussion and identification, it has a strong resemblance of "I am a piece of art on a pedestal".I like it. Rudolf
www.dipolplus.de |
#6 |
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
#7 | |
NOT!
#8 |
#9 | |
) I've learned a lot by looking for the "reasons" SL does the things he does . . .I asked specifically about the "flair" at the top . . . the tweeters should be beaming enough for it not to matter . . . but he said that he observed interaction, and there was enough of it to make it worthwhile. I'm not going to co-locate the rear tweeter like that anyway, but still wonder about the overall effect of the "bigger" baffle. |
#10 | |
Are there issues here that are lost in the model's simplicity that nevertheless have significance in the "real world"? |
| New Linkwitz "LX521" speakers.. | Remlab | Multi-Way | 542 | 18th February 2013 12:08 PM |
| Edge diffraction: large, rounded baffle, or narrow square baffle | fortyquid | Multi-Way | 23 | 12th February 2013 02:23 AM |
| Baffle size and shape -> baffle step | saschagabor | Multi-Way | 1 | 14th December 2010 10:45 AM |
| Need help designing a new cabinet/baffle with proper driver to baffle placement. | Big_Bill | Multi-Way | 17 | 16th June 2010 04:34 AM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
