#21 | |
![]() I'm still wondering about vertical polar, the effect of the bottom profile (and gap), roundover or no roundover, chamfer or no chamfer, star or angel, should any ornaments be blue . . . |
#22 |
Yes, there are quite a number of 4"ish drivers that look pretty competent from 500 to 5000 Hz. . . . I have to wonder if it's not just another "pick your poison and pretend to taste a difference" sort of thing. I find that active crossover washes out a lot of what-otherwise-might-be-significant driver differences . . .
#23 | |
I LIKE YOU
#24 |
A couple of things to consider about the upper midrange. It's not just size. It's the directional characteristics and also the effect of the blockage on the back side. The 10 is very nice since it is a neo magnet which is very small. As I said before, I tested a number of different drivers and was not satisfied with any of them. Then the 10F came out and I was pleased at its performance.
Also, I would like to point out something about those ARTA plots. They don't really say much about the consistence of the directional characteristics unless the plots are normalized by the axial response. For example, I could easily measure the response of any system at 60 degrees off axis and equalize that response to be perfectly flat at -X db and the ARTA type plots would look excellent except the on axis response might show dips and peaks. On the other hand, if the response is normalized by the axial response, the of axis contours truly reflect at what angle the response is down X, Y or Z dB vs frequency, relative to the axial response. That is why the plots I present are always normalized but the axial response. It gives a true indication of the polar response.
John k.... Music and Design NaO Dipole Loudspeakers. |
#25 | |
Now we all learned something new today!
I LIKE YOU
#26 |
That's . . . interesting . . . because from the drawings the Scan 10F, the Seas FU10 and the Vifa TG9 show similar (if not all but identical) rear profiles, despite the neo magnet in the 10F (if anything it's several of the small Tang Band drivers that appear more "open" in the rear). I don't see the difference in pictures either . . . perhaps they would appear different side by side face down on the bench.
#27 | |
Also, Deward brought up burst tests. I got into a discussion of this many years ago in that they are pretty useless tests of a raw driver. What matters is how the driver/filter combination respond. Burst response shows linear distortion which can be corrected. Linear distortion is nothing more than a deviation from a desired target. If the target is, for example a band pass response, that band pass, under ideal conditions, will have a specific burst response. Shape any driver's raw response to that target and the burst response will match the target's burst response. Any deviation form it will be the result of nonlinear distortion, or an imperfect match to the target. You can see what I did here.
#28 | |
I believe that even though the vifa has a higher Q, the HD is comparable to the SS. Vifa Tc9 ![]() SS 10f
I LIKE YOU
#29 | |
Now, if you look at the published frequency response for the 10F, the TC9 and the Seas FU10 you wil see that both the Seas and the Vifa have a bit of a rough spot between 1 and 1.5k, and at 60 degrees off axis the 10F rolls off at higher frequencies much smoother. Also, please recall that when I made the choice of the 10F I was designing the original Note with passive crossover for the panel and sensitivity was a big issue. I certainly was not going to design a speaker of this type to have a nominal sensitivity of 85dB/2.83V/M. There really weren't a lot of choices back then and all the other drivers I looked at were in the 85 to 87dB and and a couple I tested just didn't measure well at all when moving off axis. Plus, I really didn't want to use an "off" brand. The original Note would not have come to realization if the 10F had not appeared on the market. Based on its performance to date I see no reason the make a switch. The cost of the Note has been significantly reduced with the Note II and if I splurged a little on the best upper mid available I can live with that.
#30 |
That's pretty much irrevelant, because you're off both of them well above the frequency where driver "Q" matters. The distortion profiles, while different, are both admirably (and probably inaudably) low (and the different cone of the TG9 gives a different, also low, profile from the TC9). The drivers are remarkably similar in a number of ways (price excepted) . . . I'd hate to have to try to tell them apart in a "blind" test (behind active crossovers in otherwise identical speakers).
That's not to say that the Scan 10F is not a very good driver . . . it's just to say that by accident, or by luck, or by good design the Vifa (especially the TG9 version) is also a very good driver (making it a real bargain). If you're selling a "high end" speaker (or "high end" design) the Scan name alone is probably worth the extra bucks . . . it's more pain than it's worth trying to explain why you used a "cheap TV driver". Ps. It looks like John typed a bit faster than me this time . . .
| New Linkwitz "LX521" speakers.. | Remlab | Multi-Way | 542 | 18th February 2013 12:08 PM |
| Edge diffraction: large, rounded baffle, or narrow square baffle | fortyquid | Multi-Way | 23 | 12th February 2013 02:23 AM |
| Baffle size and shape -> baffle step | saschagabor | Multi-Way | 1 | 14th December 2010 10:45 AM |
| Need help designing a new cabinet/baffle with proper driver to baffle placement. | Big_Bill | Multi-Way | 17 | 16th June 2010 04:34 AM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
